7mm Yorky D's LT - Wagonery tales from the Met.
Peter Insole
The much prized Gibson is indeed inside! And I could tell a story about that too...!
Incidentally, I noted that those three central pins that are removed from the model when dismantling are loose and actually serve no useful purpose whatsoever! I can only assume that their original function was to guide the parts together during factory assembly, and should have been removed before the last part was installed??
What I'm saying is that you don't need to put them back - and there's no need to make extra holes down the middle of your new floors!
Those great ugly screw stems intruding into the interiors at the rear corners were also a result of moulding limitations!
Although I suspect that it would be one hell of job to grind them out - I must admit that I would be sorely tempted to have a go... especially those that obtrusively poke through long seats in the lower saloon...?!
Dave, what does it feel like being a guinea pig - er, sorry, I meant trail blazer?!
Pete.
I've just been looking at these and have an idea for both the upper and lower saloon rear mounting points...... as they say - watch this space. I'm probably one of the many who don't have a fully equipped machine shop.
Just cannot get off the London Eye - err large hamster wheel :) - to trail blaze. In fact detailing (rebuilding more like) the RT to bring it up to a reasonable standard is a new challenge in some ways as you're working with two incompatible media (zinc alloy and plastic) which have already been cast into shape. One thing I've never tried though is soldering die cast zinc alloy.
Although you can buy an O scale LT pannier for £200 I would suspect an O scale RT made to the same standard would be a similar price and probably not sell in the same quantities.
Peter Insole
Sorry Dave, I was getting a bit carried away with my enthusiasm for this one...?
I shall indeed continue to eagerly watch this space!
Pete.
Nothing to be sorry about Pete.
I'm just as enthusiastic - it was this photo I found on the t'interweb which started it. This is outside Tring garage and must have been taken in 1968-69 as the LONDON TRANSPORT roundel is present on the garage offices. I suspect it was a crew change as the conductor is carrying a Gibson ticket machine box with his cap perched on it. The bus stop E plates are for routes 301, 387, 706 and United Counties 61. The bus stop visible in the background above the conductor's head was the alighting point for northbound services terminating at Tring garage.
Anyway continuing with the RT story I have managed to remove most of the rear lower saloon mounting points.
Firstly I mixed up some Super Steel and applied this around the part of the mounting point I wished to retain just to beef it up a bit. Then it took two nights with slitting discs and grinders in the old Dremel. The near side post is a bit easier as you can get a slitting disc in the rear door. The Offside post is less accessible and I cut as many slots as I could into the post then ground out the remaining pieces. There are two 10mm stubs left which are just below the longitudinal seat height.
Due to the way the lower saloon floor is installed the longitudinal seat backs will have to be fixed to the body. Here are some photos of the current state of play. The upper saloon rear mounting posts are going to take a bit more thinking about.
Nearside
The result
Peter Insole
Aha! you've only gone and done it Dave!!
Result indeed!
That is just what I was thinking - but was much too afraid to actually do!
The thought of poking in there amongst all that unknown metal with whizzing discs and grinding wheels, potentially wrecking an otherwise super model terrified the living daylights out of me!
I fully appreciate how long it took to do too, although I am absolutely sure that the effort is fully justified?!
At least the upper deck ones are perhaps not quite so obtrusive, but they would still be bugging me too!
You are doing a fantastic job - and following your lead, I am now beginning to look forward to tackling the cupboard queens back here!!
Hmm...? (thinks)...
There were those 'andsome Green Line jobs, with their delightful cast bullseyes 'tween decks, and yellow blinds 721 to Aldgate...
But then again; what about a nice 7RT10, (roofbox) RTL on the 25 maybe...??
Oooooooh - stoppit!
Pete.
RT 4751
Oooooooh - stoppit!
Shades of Kenneth Williams - Stop messing about!
I know - there are loads to choose from - as I alluded to earlier I think a red RT is on the cards now. Was route 84 but might now be 142 or 258 ??
Having removed most of the lower saloon mounting columns naturally the upper saloon really needed attention so I went to my local independent hardware store and purchased these for use in the minidrill (which has a flexible drive). They are milling cutters which I used (with some tapping fluid provided by my neighbour) to grind out the upper parts of the upper saloon mounting columns. Initially a daunting process but became easier when I worked out the best way to hold the device to efficiently remove the material.
This is the result, not pretty by any standard as I have to tidy up some tiny nicks. Again about 10mm is left. RT 4751 30.jpg
I also removed the top part of the front upper saloon mounting columns to eliminate the slight hump when viewed from the front. RT 4751 35.jpg
Hopefully this should be the end of the 'heavy engineering'......
RT 4751
Now moving onto some of the smaller details......:eek:
I've made up a pair of LT 'ears' or indicators as later fitted to RTs, RF buses and early Green Line coaches (the 'modified' Green Line coaches with the light green waist stripe had a different style fitted), RMs etc.
The indicators were made up from brass tube. rod and scrap nickel silver etch. The orange surround is car head/rear light repair tape stuck onto the indicator and the inside removed to represent the frame.
I have not made the cantrail fitting bracket as these 'ears' can then be used on different buses. The bracket will be made up separately as part of the rebuild.
Then onto the rear, again car head/rear light repair tape (double layer this time) was used to make up the left indicator arrow panel and the blanking plate over the left arrow of the double arrow indicator originally fitted to the RTs.
2-Bil
YD---and others______Got any E plates? might pay you to have a rummage---one for route 717 sold yesterday --------£2,2oo Hammer price---------enjoying the build,info and photos-----Respects BW
2-Bil
712-Radlet/St Albans/Luton went for £500 & 712 Morden,Epsom,Dorking for £200 which you likely know seems the rough mean average for Green Line plates.Dunno any results for 706/713 though if you're like me with my Brighton Line Totems and Targets you'll not likely part with them .Hope you don't mind a short modest meander from the modelling----------------
No worries whatsoever.
Too right - the 301, 706, 712/713 and United Counties 6 E plates have memories as I have travelled and lived on these routes.
SR style totems I presume :).... and not the BR 'hot dog' or 'sausage'.
Peter Insole
Dave, that would be a bit of fun - even though I suspect that leaving it in the "cubby hole" rather than putting it away in the locker would be an instant dismissal offence for the conductor?! After all, the case contained cash!
An irresistible bit of fun though, so here are the dimensions:
In plan; 12" long by 8" wide. Depth 6".
Gibson shown for size - can measure that along with the harness as well later (when I get home from work this evening!),
if you are tempted to go the whole hog that is...?!
Pete.
