Peter Cross
Hi all
This is being constructed from an Ace models kit. It is of mixed parentage. Some of the etches have McG0wens on and others are drawn by William. With luck they should all fit in the right places. I expect like others in the range it will take a little builder input.
The Pictures came in an odd order. So not as I constructed.
The frames together with all the wheels on. Ready for all the detailing.
Hopefully this method of side control and springging will work for the radial axle. It seems to from a short test I did.
The radial before adding to the frames.
The frames and side beams during modification and making.
The radial in place. It has been working very well, apart from one tight spot. I am not sure if it would ever get into the position when working. But I will rectify it before long.
The side beams and front axle pivot beam, which still needs the support fitting at lose end.
I will post more shortly. Hope you will find this build interesting
