David Varley
Looking good so far, Ian
That's beautifully finished, the paintwork is incredibly neat considering the size.So here is the "finished" box.
Thank you Adrian. The painting was made easier by having separate windows, the stonework was down first, followed by the brickwork. The raised framing was next followed by the planked areas. The roof is a separate item that just clips in place between the guttering (it will also allow me access to the interior so that I can fit levers and other details after Christmas). The downpipes, windows and open door upstairs were also added once everything else was done - annoyingly there is a bit of discolouration (which shows up mainly in the photos) around the downpipes fixings which needs to be addressed. Obviously it needs a little weathering too.That's beautifully finished, the paintwork is incredibly neat considering the size.
Thank you John.Agreed your work is always lovely Ian
Thank you David. Stone and brickwork were painted all over in mortar colour, then the bricks/stones picked out with a dry brush / side of brush technique. Odd areas of mortar had to be cleaned out afterwards with a toothpick, I'm hopeful that weathering will make it look a bit better.I particularly like the stonework but the rest of it's very nice too - good job Ian![]()
That's looking very impressive - I know you say you aren't an artist but I'd disagree. TheOver the last few weeks I have been beavering away on Modbury to get a little more done in time for it's second public appearance at the 2mm Association's "Supermeet" on the 25th June at Tutbury (near Burton upon Trent).
That's looking very impressive - I know you say you aren't an artist but I'd disagree. Theclumpcopse of trees are nicely done and have a definite 3D appearance, I had a double take at one photo to check you hadn't put a 3D tree in front of them. It's almost a shame to hide them.
I'm hoping to get down to Tutbury so look forward to seeing this in the flesh.
I'm the same as Adrian, I had to take another look I thought you had put trees in there. Wish I could paint like that.
Len
Very impressive - how do you do the split chassis insulation? You talk about insulating material in the main block for the screws, is this tufnol bar glued in or something similar? Also the position of the bushes for the gear pinions - do you use a jig to mark out the centre points or is it just done by eye?
It does thank you, I can understand how it works now. I'm currently in the planning stage for the coal tank chassis and being cognisant of Jerry's advice of getting as much weight in as possible I can see the attraction of a solid brass chassis so I'm just weighing up the different solutions.I hope that answers your questions.
