Dan Randall
The last picture might just give away where they're going to end up me thinks![]()
I was thinking that too! Very nice work Mick.
Dan
I like the little green engine in the background - is it DCC?
I particularly like B920059.......could you describe how you achieved the rust & weathering effects ?
Cheers Phill
Thanks Mick
I particularly like the rust effects within the panels of this vehicle, do you work the mix mentioned above around the edges of the panels or do the whole panel & clean it back to the base colour in the middle of the panel ?
Cheers Phill
Coming along very nicely, Mick. Lovely work!Really like the trestle.
Very nearly finished these batch of wagons, the pictures aren't great as they're from an old camera, the two vans on the end still need some work
ATB Mick
That microwave will have to go if you're going to get the track round the corner!Excellent work Mick......nice work tops too
Hi Mick, Would you fancy doing a run through of your weathering technique as used on the bolster etc.?
In any case the wife won't tollerate much more intrusion into her domain ! Rob, when I have a little more time i'll write up a bit on my limited weathering experience, products etc..........I don't mind going through it at all Rob, although I do feel a bit of a fraud in as much as they are techniques practiced by many others and are certainly not exclusively mine.........
......... when I have a little more time i'll write up a bit on my limited weathering experience, products etc..
ATB Mick
I think you've made an excellent job of weathering those wagons and everybody has their own techniques and style which we all learn from
Come on don't be shy mateI think you've made an excellent job of weathering those wagons and everybody has their own techniques and style which we all learn from
ATB, Col![]()
I'll scrible some bits down this week I think and invite tips from you old hands to steer me on the right path
Hi Mick are you using the MMP underframe kit too?. I have the W Irons and underframe kit but still need to get the overlays for the inside (I wasn't sure exactly which wagon I had when I ordered from David so had to wait until I went up to the cottage again to have a look at the kitOk, an update after what seems like an age since I did any modelling and even longer since I got onto the PC and had a good look through here. I've been finishing off a couple of Slater's Vans in F/S
View attachment 10460View attachment 10461View attachment 10462
And here's what I've managed to get done at York Show whilst on the S7 stand. The brass overlays and W-irons are as you've probably guessed, MMP, which I really do like. A great addition to the pre-printed Slater's bodies. I had a bit of trouble first time round with this one, using evo stick to fix them is a fiddly job. Following advice I'm going to try first using spray mount to stick them to 10thou plasticard and then fix them to the sides. I'll let you know how it goes
P.S there's a great article in an old S7 newsletter about photographing your models and yes I haven't read it yet
ATB Mick
