Stevers
In this case it was a new Anycubic resin vat with pristine factory tensioned FEP, and I did manage one complete perfectly formed half interior.Make sure the FEP is taut, sort of "soft drum skin", and make sure the retract height is sufficient - I think mine is 7mm and I have not had any issues.
With very little imagination I can see the pattern the stretched FEP made in the floor of the defective half as it didn't release. The degree of lift required must be proportional to the size of the bed all other things being equal; is your machine the same sort of size as an Anycubic Photon Mono? Even 6mm of deflection on that drum tight FEP would require a fair bit of force, but that would seem to be "wur 'tis"!
To aid separation I've increased the second stage of lift to 4mm (7mm total) and slightly slowed lift speed to 4.5mm/s from 6mm/s. I've also upped the exposure to 2.3s. The models have been rotated on the plate so that the previously defective half is now on the candidate 'good' side. I just need one more good half or just one that I can patch with seats and tables I already have.
I'm washing in water laced with IPA, and am using IPA in a spray bottle for a final rinse and any cleaning. I'll switch to Bio-Ethanol (from an actual shop I can walk to) when my free bottle of IPA runs out.
The flash really shows up that bright yellow interior. This being a test fit of one good half and one repaired half glued together and fitting perfectly. It's a relief that the headrests are visible after so much trouble! If anyone else is about to do one of these and is reading this - make sure all those bits and bobs under the underframe are perfectly straight before the glue goes off! There are some Preiser seated passengers on the way to me to help bring it to life.
