Tales from The Room of Doom. Dipping a toe in various bucolic backwaters.
Pete_S
Hi Rob.
Yes it is. Getting the ruler out, it looks like a difference of 1mm through the buffer centres.
An 8-compartment Third could be carrying 5 Tons of passengers (assuming 10st/pass & 10 pass/compt). That ought to flatten the springs a bit.
Flicking through what drawings I have (plus a dip into Russells Big Book of all Engines & That) suggests GWR C&W stock to have 3'5" to 3'5-1/2" buffer heights. Locos are 3'3" (850 class) and 3'4-1/2" (Star, 56XX). Tenders all seem to sit at 3'5".
Noted, but.....these don't sag with added weight and wagons from Hornby and Rapido all share the same buffer height as the brake third. That said, I do see your point, Pete. and arguably the reletive buffer height of carriage and loco, based on your quoted figures, seems pretty prototypical......but it looks odd to these eyes.
Other locos checked all have the same buffer height as the coach.
This is my other 517 with the same coach.
It's intriguing.
Simon H
It's intriguing.
Intriguing indeed...oddly, differing buffer heights are quite common on continental H0 models; Märklin/Trix and Fleischmann often being noticeably taller than most others. I must say, 1159 is ever so tempting; just as well I don't model in 00!
Simon.
