Rewanui (1940 NZR in 1:64)
Overseer
For those not familiar with NZR tarpaulins this photograph might help to show what Lawrence is trying to achieve. It looks like a 1930s view showing both traditional black dressed tarps (hot linseed oil and tar coated canvas) and 'modern' commercial canvas tarps. It also shows the grab handles well and truly covered by the tarps.
Tarps are very difficult to model convincingly so it will be good to see some convincing tarps on wagons.
Lawrence Boul
WHERE DID YOU FIND THAT?? (I tracked it down to Culture Waitaki) I've been trying for months to find a single image of tarps from that era!!
So thanks a lot.
Krusty will doubtless have things to say.
Lawrence Boul
A friend who knows about this stuff says "Car to the left is a 1936 Ford V8. Car in the foreground is a 1934 Hudson Terraplane. The truck along the road is a 1935 Chevrolet. So, the earliest it can be is 1936." Given that none of the vehicles is likely to be brand new, this would date the photo to the late 30s, or maybe early 40s, which means this look is just what I need to achieve.
Lawrence Boul
Staying with the 4 wheel wagon theme, 3D printing has obviously revolutionised what is possible.
My first printed kits (as built by @Overseer) were, more or less, derived straight from the original drawings.
This wagon (1/64 from a few years ago) has a 3D printed body on an etched underframe that in an earlier iteration carried an injection moulded body sourced from others. The print was quite an improvement. It didn't need fettling and filling, wasn't constrained by avoiding undercuts and had details like the chains to retain the door pins. Wagons like this though suffer somewhat from the uniformity and lack of character typical of RTR, and are somewhat soulless. (This example still awaiting hoses. The frustration of sidechains also evident).
It didn't take me too long to start thinking about distressing the underlying 3D model. It is not at all difficult to distort planks, replicate loose hinges etc to get something that looks a bit more used.
This one is 9mm/ft I think, but is the only image handy to show the initial development where the doors were allowed to sag and hang outwards against the pins. This simple step improves things quite a bit.
Shortly after, I was working on a simple coaling stage. This is possibly the most boring and featureless subject imaginable without the inclusion of character due to the vicissitudes of hard use. So I put in some effort to beat it up a bit. This was achieved by a) adding warp and twist to the planks and b) adding wood grain.
Grain is added (in Blender) by adding a texture to the timbers based on a real image of weathered planks. This is real 3D texture, not just a graphic fudge. The image shows my first attempt which I felt worked extremely well and was somewhat by luck than management. This printed timber was painted a light/mid grey and then treated with a black/brown enamel wash. That's it.
Thus encouraged, I predictably wanted some of this on wooden wagons as well.
This one is 9mm/ft. Wood grain, per se is not especially visible on the outside of a painted wagon. On the inside it can be heavier as, a) loads and weather will etch the timber a bit, and b) extra relief will allow weathering to show the grain. Depth of grain is very easy to adjust in software.
Around the time I was doing this @KrustySimplex pointed out that the distress in weathered timbers is primarily cracking not grain as such. If one can stand the critique, the merit of putting up one's work is that such observations lead to improvement.
Adding cracks is quite a bit easier than adding grain. That's useful as grain is exhausting and files get quite large (=slow). Being relatively simple cracking can realistically be varied between prints for an individual look.
L1-1350.jpgThis example (back to 1:64) is the latest iteration of an increasingly protracted development. Timber has grain and cracks (subtle here, but very worthwhile in the flesh). The model is printed in 1 piece with an etched brass floor (plus the odd cast and etched detail). Grain on the brass floor is drawn on with a pencil.
Couplers are now finally correct for my 1940 period. Thanks to prototype research from @KrustySimplex, I'm now able to get the combination of wagon body/underframe/axlebox/handgrab etc correct for the wagon number applied.
Another 1:64 highsider showing the underframe. Almost everything here is a single print (including axleboxes, brake shoes, brake stretchers and loops) other than brake linkages (etch/wire), shunters step, handgrabs etc. Axleguards are etch and the wagon has sprung suspension based on guitar string. Cat hair included at no extra charge.
These latest wagons are probably as far as I'm ever likely to go. I'm working on my painting, and doubtless there will be some incremental improvements in the models, software and printer capability. But there is a lot of work to bring other aspects of the layout to this standard, so it's unlikely I'll be putting much more effort into wooden highsiders.
Now I just need to build a fleet. Not too daunting as these things can be assembled in an hour or so. Painting them takes considerably longer.
Lawrence Boul
One of the banes of modelling the NZR is fitting side chains.
I've gone through various phases with this.
  • Way back, I formed the hooks from wire.
  • Then I etched a fret of hooks.
  • The next step was to cast them. The latest iteration is superb, but doesn't remove the need to sort out suitable chain and actually fit them (which involves breaking two links). Good for locomotives where robustness is critical, painful in all cases.
  • The final phase was to print the hook, chain and eye as one piece, but with the links free and separate. The link through hook and eye are not free in practice (in 1:64 anyway), but this doesn't affect the look or their ability to swing free.
The image is a 9mm wagon and an intermediate stage with cast eye, but the idea should be clear. The print supports are a bit heavy in this one, but from memory it represents my first try.
This works extremely well. It makes a task that took ages into a few seconds work. The result is scale and looks like it would take a load (cutlinks always look naff even if an effort is made to solder them closed). It works just as well in 1:64 and has proven perfectly robust. There's no load and the only real risk is snapping off the eye. Should that happen it's an easy thing to fix.
Lawrence Boul
Rewanui had a problem common to many layouts: how to hide the transition to the fiddle yard (of which there are two)? The first was easy since the real thing had tunnels that could be relocated. The second, in the foreground was trickier. The answer was a repositioned building modelled in relief as mentioned earlier in this thread.
I've always rather liked the building with its monolithic structure and church-like windows - a stark contrast to the weatherboard of the other structures at station level. I had quite a few images, but having conceived the idea to reposition it I needed some measurements. While it still exists, it's a day trip expedition to get there. Fortunately a search of Archives NZ turned up this:
It's not exactly as built, but together with the images, totally adequate to make my model. As it's mirrored and sliced obliquely, I can't get too hung up about the nearest mm.
The model is a styrene carcass with 3D printed doors, window reveals, chimney and the detailed areas of the foundation. Windows are laser cut.
This view of the CAD model shows the 3D prints (in grey) and the way the building was sliced at the backscene. The nearside foundation was not rendered, so I printed it to show the imprint of the timber boxing. The gutters/barges /soffits were one piece and arranged in a way that they positively located to the styrene walls. The styrene 'iron' roof (not drawn) sits over this.
In this progress shot the difference between the rendered and backside foundation finish is obvious. Also the way that the guttering is captured and made very robust by amalgamating it with the other parts.
The lamp shade was formed from shim in a simple 3D printed 2 part press tool.
The real thing in 1987.
Lawrence Boul
Based on the vehicles it must be post-1936, so say c.1938. Invaluable for me.
Overseer
Happy to help. You will probably have seen the following images from The New Zealand Railway Magazine in the 1920s. The new tarp shop was built at Addington in 1926, published in Vol 1, Issue 5, 24 September 1926. This is a late date for the construction of a high clearance building to hang linseed oil dressed tarps (Victorian Railways stopped dressing tarps in 1924) but is reported to have continued in use for quite a few years. The North Island tarp shop was at East Town Workshops, Wanganui.
Lawrence Boul
This just shows I need to get a life...
Addington was still dressing tarps with Linseed oil way later than 1926. As this memo alludes, they tried the wax dressed tarp used in Australia, and these are probably the light tarps in the 30s photo. They were not particularly successful in NZ and it was a problem they sought a solution to. #3 and #4 involve linseed oil in 1941.
Overseer
I think that is interesting, mainly for the lack of standardisation. I have attached a pdf file of a section of a Conservation Management Plan I wrote for the Tarp Shop at Newport Workshops in 2012 for a summary of the tarp situation in Victoria.
  • Newport Tarp Shop CMP extract.pdf
Lawrence Boul
@KrustySimplex is more knowledgeable than I on the matter, but it seems likely that NZR were trying the various solutions that were working in Australia. The advantages of wax dressing suitable for immediate use v hanging for 3 weeks are obvious. So the fact that they went back to linseed oil and vegetable black suggests that the wax was ineffective here.
Clearly they were using linseed oil in '42, and being none too careful about it either:
Lawrence Boul
Back to modelling...
One of the stars in the Rewanui show is the humble hopper wagon: class Q. These came in a number of flavours, but in 1940 they were all unbraked wagons of 8.5ton capacity. The hoppers were removable and on the wharf were craned over the ship's hold and discharged through the bottom doors. There were two distinct fleets, and only the Greymouth Qs were found at Rewanui. That means that some attention needs to be paid as not all varieties and variations are appropriate and wagon orientation and asymmetric lettering need to be observed. Handbrakes were arranged to be trailing on the gradient, door mechanisms were accessible to the 'wharfies' and wagon numbers visible to those tallying loads. As mine and port arrangements differed at Westport, so did these details.
I have, over the years, done quite a few iterations of hopper kits. My very first kit (in pewter) was a Q5. I've scratchbuilt and etched Q1, done etched kits for Q2/3 (before realising these were Westport only) and etched Q4 as well. All of these were reasonable, but all were time consuming. Punching rivets in steel hoppers is fun the first time, but if you need a fleet the appeal palls quickly.
So with the layout progressing I looked for a more practical method, for the numerous Q5.
The spec is:
  • quick to build
  • sprung
  • sufficiently heavy to perform
  • detailed inside and out
The result is an etched subframe, 3D printed visible underframe, cast platforms for weight and a 1 piece printed hopper.
_HLB1975.jpgHere's the subframe. A simple fold up with clip in crossmembers and a few solder joints. All the bits where strength and dimensional stability are needed.
The pretty bits are added. This is a positive fit.
Cast end platforms with the handbrake hanger, coupler mounts integrated and wire handgrabs added.
Again a clip fit - though obviously ultimately glued.
Suspension sorted. Cast sidechain parts, now revised to assemblies printed in one go.
The end (more or less) result. As with many of my projects, the problems have all been solved, so efforts have paused while I look at other choke points.
I need Q1, Q4, Q5 (here) and Q7 for Rewanui. Q1 and 4 have steel underframes and hoppers so my etched kits for those are being maintained, but the elegant, though interminable, etched hoppers have been replaced with prints. The fairly rare Q7 is a wooden hopper (similar to that above, but different) in a reused Q4 underframe.
So the hopper solutions are on hand, but I now need to build some...
If you can face it, the extended play version of this potted history is here: Coals to Greymouth – NEW ZEALAND FINESCALE
Lawrence Boul
Rewanui related (definitely), on topic (a bit), and large (1:34).
Sharp Stewart delivered the 4-8-0 B class engines around 1900. Their long wheelbase and lack of flexibility was hard on contemporary track and this, with changing needs, resulted in 2 of them being rebuilt within a few years to WE class 4-6-4T. For most of their working lives these engines were associated with the Rewanui line. Around 40 years later (1943) a third B was converted to become number 375. It had some slight visual differences and is the subject of this model.
I've got a kit for these engines in 1:64 languishing in the 'must finish' dept. but responding to some requests I started building some in 9mm. One of the advantages of digital models is that if there is a need to change scale this is relatively simple to do. There are some hazards to simple rescaling, but overall it is relatively simple.
This is the test assembly of the body etch, with 3d printed side tanks. The various assemblies are just placed resulting in the odd gap and misalignment. There's some solder still to clean up too. I find superstructures relatively low stress as they just need to look nice without any worries about functionality. I'm currently waiting on bits for the chassis, so it was the only place to start.
I'm a fan of split frames, and the way I manage this is to do the chassis as a short unit carrying cylinders and bogie/truck mounting. The frames at front and rear are modelled as part of the body. This removes problems in insulating headstocks, mounting cowcatchers etc. It is fairly easy to hide the breaks in the frames behind the cylinders and cab footsteps.
The cab roof, inside F/R cab skins and floor are a single plug in unit. This makes detailing and maintenance simple and the cab roof can never just fall off. it does mean the crew need to keep their arms inside the cab though.
Lawrence Boul
NZR modelling generally involves doing things with no mainstream commercial support in unpopular scales. One of the ironies is that our scale gauge combinations were derived (in the mists of time) so that proprietary track and mechanisms could be used, yet both were quickly outgrown as they seldom represent the prototype at all well. Using HO track and turnouts remains common for those of a less critical nature and is a reasonable compromise in situations where the undernourished sleepers are not apparent.
Hand laid track is, of course, an option, and if modelling a period with flat bottom rail spiked directly to sleepers then this is OK. For rarely traversed track spiking might be appropriate in later periods and even chaired bullhead was not totally unknown. But screwed, bedplated track is more appropriate for me.
I needed Fell centre rail too and my journey there is here: More Fell deeds – NEW ZEALAND FINESCALE
3D printing plain track and turnouts was a logical thing to try and worked well (track has been down and running for a few years). I can print 5x approx 200mm of sleepers at a time, so 1m or so of flex track at a time. So very practical for a relatively small layout like Rewanui.
But turnouts were the more interesting bit.
This is the frog of a 1:7.5 turnout modelled after the 1926 pattern 70lb rail drawings. I used code 82 which is a bit overscale, but I wanted steel and that's all I could get. This image shows a test piece using nickel silver and before the sleepers had woodgrain added. There are standard bedplates, spikes and custom fittings used here. The turnout can be printed in 3 parts on my bed and takes little time.
This is the Y. Not that common and I had to infer the design. The Rewanui station yard is all standard 1:7.5, except this one which leads to the backshunt.
None of this is all that clever. Just drawing the prototype parts in CAD and then trial and error to tweak things so that they fit available rail and adjusting tolerances for pragmatism and robustness. The individual track fixings are fragile, but collectively robust.
Somewhat more clever was printing jigs to file the rails. These result in very reproducible and accurate parts without much effort. They might only do 1 or 2 turnouts, but they are quick and easy to print so that is not problematic.
These are the finished turnouts in steel with textured sleepers. After laying, they were completely buried in ballast, so none of this is actually visible, other than the area of the switch and parts of the frog area. Arguably wasted effort I suppose, but an interesting exercise, and any future use outside a yard will need the detail, so I console myself it was an investment.
Lawrence Boul
At the time I was looking at track, I was also playing with DCC-Ex. This system allows VERY cost effective turnout control via an I2C bus using servos.
The idea is that there are wire droppers on the switchblades that go through narrow slots in a baseplate to a hidden tie bar. The linear motion of the switch is achieved by an internal cam mounted on the servo. Switching is via an external cam surface operating a micro switch. With CAD and 3D printing this is relatively straightforward, although it took a few iterations to deal with the vagaries of inexpensive servos and real world tolerances.
Possibly the the major issue was that nominally 180 degree servos actually do not deliver full range, which required some rethinking and testing of cam shapes. But it all works pretty well. It is a bit on the noisy side, but at an exhibition this is not a factor. More expensive servos would be better, but a bit of silicon grease helps a lot.
This is the full arrangement. The ghosted parts are commercial components (servo/switch) In green metal parts (Mounting dowels from China, and wire). The cam is in red and other printed parts in grey. The lugs on top locate with the long sleepers at the toe of the switch.
With baseplate removed, the functional tiebar is visible. The wires to the blades sit (and are soldered to) some brass PCB hollow rivets sitting in the tiebar. This provides secure attachment and some decent area for mechanical performance.
The cam with the actuating dowel shown that is fitted to the lower face of the tiebar, here sitting in a mid position. The external cam for the microswitch was easy to sort. The eventual understanding that I was getting less that 180 degrees, coping with tolerance to achieve full throw and the discrete cam positioning due to the spline on the servo meant some mucking about with cam design was needed (The cam shown is the original design). That's easy to do though and they are quick and cheap to print. It's relatively simple to change servos out if needed. It works well and I'm happy with it, but as is the nature of such things the experience suggested ways to improve it.
If I was doing it again I would probably engineer a cassette arrangement where the assembly could be tested off the layout and then clipped in place. This is compact and elegant, but a bit of a fiddle to set up in situ. A micro stepper linear drive might also be an option
The cosmetic head rod is soldered in place from wire. It is then cut (for insulation) and then made entire by fitting some thin wall Teflon tube over the cut ends.
great minds - I have been working on servo drives for turnouts, on and off for some time. Arduinos offer the control, and can easily be interfaced with a CAN bus, which is the architecture I have elected to pursue for everything that is not loco control which remains DCC (I do have a couple of R/C but they are the exception and are not really intended for regular use - more an experiment).
CAN has many advantages, it is very tolerant of electrical noise, and can effectively work "plug and play" - for example, a lever frame can be plugged into the bus outdoors on a nice day, and indoors if the weather is inclement - though I guess you might not want the trains running in the rain. And lights, etc., can all be controlled by similar CAN compliant modules.
I saw an elegant solution for the servo cam drive a week or two back, I think it was one of the guys who are regular contributors to the Templot forum - rather than a cam, it used an eccentric and a small profile rolling element bearing. I didn't see or hear it operating, but it looked to be very well designed, with space to fit up to 4 microswitches I think. It's quite a bit bigger than your design, but that doesn't worry me as I am working in 7mm.
The beauty of a cam or eccentric drive is that the blades are pretty much locked with negligible power demand, backdrive is not possible. I guess that could also be a disadvantage, but generally I think not.
