Giles' misc. Work bench.
Osgood
And if you thought the words SINATRA and LUFFING are an unlikely pairing, try asking Al - he'll put you straight :)
Ian@StEnochs
Excellent work Giles, but unfortunately the rapid oscillation of the load spoils the effect. The pendulums effect, the shorter it is the faster it swings. However we all know one cannot scale everything down so this is not a criticism of your work.
Giles
I've not tuned the transmitter to slow/soft-start the inputs or limit speeds yet, as I still have balancing work to so on the crane, and I need to replace the hook, which needs to be a bit heavier to draw the lines down better. Tuning will mitigate this problem somewhat, though not cure it entirely of course. I also have glazing and weathering to do!
Hopefully in a few days we will get the final effect!
SimonT
Well, as a demo of its first run I think it is magnificent. We also now have a unit of measurement to rival the 3d/6d bits, the Route Master, Nelson's Column or the Blue Whale (how many people have seen one?). Giles' glasses!
