What's that you ask? It's a strip of vinyl grass glued to the backscene along its lower edge with Evostik...
The upper edge was then folded down over crumpled paper...
....Ang glued down to the roadway with the aid of a heat gun to soften the vinyl...
Scenic stuff was glued along the top against the backscene and grass was glued along the road side. The Ratio fence was sprayed with Halfords Plastic Primer followed by my sandstone colour as used on the platform edge stones. Finally it was weathered and glued to the backscene...
A protective glove is vital when using a heat gun....
