4mm Llanfair ....
Viewed from the bridge. Some work was done around and on the water tank plus every length of rail was given a new coat of rust...
In the short term I would leave the space between the main line and headshunt as in the photo. When you are laying the scenery at the front you may have a better idea of could fill the space. I would be inclined to make some sleeper indentations as if a loop had been lifted and being taken over by nature with weed patches and young bushes.
LarryG
.... When you are laying the scenery at the front you may have a better idea of could fill the space. I would be inclined to make some sleeper indentations as if a loop had been lifted and being taken over by nature with weed patches and young bushes.
Funnily enough, the sleeper indentations between the two tracks are already there although you have to look for them. They're from a previous headshunt and roughly follow the line of the grass strip.
A signal will go in there and possibly a fogmans hut and a pile of sleepers.
LarryG
I mentioned recently that the laser cut brickwork on the goods shed office needed attention. Raiding the spare buildings box produced an Intentio GCR weighbridge built a couple of years ago. A long chimney stack came from spares. Temporarily in position tonight for the photos...
The stack is clumsy, so I need to find something better....
Nick C
I think the chimney would look better either at the other end of the building, or flush with the main shed wall - being stand-alone but so close is what makes it look odd.
RichardG
Larry, if you change the chimney stack, it would be worthwhile making the new one a bit taller so the pot is above the ridge of the main roof. Then the imaginary fire will draw better. Moving the stack as @Nick C suggests would improve the overall look too.
LarryG
The goods office now has a deep set fireplace with the chimney built into the goods shed wall to give some heat to this building. Llanfyllin goods had a similar arrangement. The office still needs bedding in...
The goods shed was only lightly glued down, so it was taken indoors and all the paintwork given a fresh coat of GWR Stone nos. 2 and 3. Again, the photo has reminded me the hinges need picking out...
LarryG
It looks different because of the new open-plan goods yard.....
The goods and coal roads have changed places and yard is now wider...
The yard looks more open and rural now with less clutter hence the removal of the Provender Store.....
