westernfan
I recently acquired a D J Parkins post-war products cct kit built o gauge model that was in dire need of a make over what with its poor paintwork and use of cardboard for the floor and a need to reglaze the windows
Step one was to remove all the paint from the brass body, being on a tight budget, have you seen the cost of nitromoors stripper lately and the nearest diy or ironmongers is a 16 mile round trip I rummaged around the shed for some brake fluid. This was brushed on to the model and left over night but with no effect I then noticed that the fluid was synthetic so on to my second attempt, swmbo mentioned that there was a bottle of oven pride under the kitchen sink, the contents is a caustic gel-like solution which I applied with a half inch brush and popped into a bread bag and left for approx two hours to do its stuff on the paintwork this second attempt was successful
I then washed off the gel with warm soapy water and then immersed the model in a bowl of warm water and a drop of bleach to remove any detergent residue
The next step was to replace the warped cardboard floor and partitions with plastikard and then spray primer the model ready for its repaint
I used a mixture of humbrol acrylic and railmatch enamel paints and used both air and brush techniques to paint the model, hmrs presfix transfers were applied and a couple of coats of railmatch matt varnish sprayed on to finish off the paint job
The next step was to glaze the model I used some extruded copolyester which was then glued to the inside using araldite I fabricated the security bars from some slaters 30thou plastic rod
All I need to do now is to build another o gauge layout to run it on
