A Layout Called CHIMTONSTOKE
David Waite
All the holes are done and the Aluminium Back trimmed to its finished size.
The two outer most holes in the circle section are for the wires to enter the instrument, the four small partly recessed milled holes are representing
the ends of screws finishing in tapped holes entering from the other side, these screws two per side held a screw terminal
to the back that the line wires attached to and the enamel wires from the coil connected to, the top hole and lower hole were originally
there to hold the instruments mechanism to the back but I am using these holes to hold the second section of Aluminium to the back
and as for the little hole in the middle I have no idea it is there on the prototype so I drilled it, maybe a oil hole for the rear bearing?.
Next is the second half of the back to be made this piece of Aluminium is 86mm x 86mm and is 25mm thick
The block was turned down to a diameter slightly larger than the outer circle diameter of the back piece already made.
The block was spun around to start the machining the only reason I am still using the 8"four jaw chuck is
my three jaw chuck was at its limit and this was a safer way to go.
Most of the main turning is done the section under the jaws still needs to be thinned down.
A trial fit of the Brass Casing when the piece under the jaws is turned a little more the Brass Casing will slide
further along.
On to the mill for the next stage shown here are sections of the inside of the back flange being cut away this is to allow clearance for the mechanism leaving behind two protruding block pieces these will have tapped holes in them for the two screws to attach this Aluminium piece to the Aluminium Back.
Back to the lathe and this time clamped in the three jaw chuck to turn the flange a little more there is still some turning to
be done to the piece that is left but due to its shape being easily damaged I will leave it to last.
The Aluminium piece will need to be machined down a little once I decide on what thickness of glass I will be using.
A face plate was turned up with a slide fit into the brass casing.
There is no plan for this part of the build I'm just working it out as I go along, so far so good.
David Waite
Next part I made was the Tapered spacer ring that sits between the glass and the face plate I finally used up my largest
piece of solid round steel stock I'm glad to see it all used up but wish I still had it for other things.
Trimmed down to the correct OD and faced off.
Bored out parallel to the smallest diameter of the taper.
I cut the taper to the 8mm depth starting 1mm in from the outer front edge.
Parting off.
The test all ok.
I wanted a change of pace so I turned the Two Brass Thumb screws.
I turned the diameter then ran the knurling tool along
I turned the shapes, drilled and tapped a 1/8"WW threaded hole in the end for the brass screw thread to fit in then parted it off.
The stock left in the chuck was drilled and tapped so it could hold the piece for facing it off.
I don't know why I never thought of this idea of cutting the glass before the idea just came from nowhere into my head when I was laying in bed thinking about what sequence of events I need to do on the instrument for the next days progress so here is my invention.
I removed the Diamond cutting head off my glass cutter I then bent up a piece of very hard rod and screwed it tightly into the diamond head I then removed the cutting blade off my adjustable hole cutter and with a washer fitted the rod in its place, next I removed the V belt off the pedestal drill and by turning the extension of the hole cutter and at the same time with light pressure on the down feed spindle hey presto a perfect scribed circle
See it works, the lovely scribed circle is still there but the roughness was done by the pliers chipping away the unwanted glass bits it won't be seen so it doesn't matter.
Now that I had the glass thickness at hand I could trim the back Aluminium piece to its correct length allowing a few thou movement for the glass.
All assembled to check the fitting of the parts, this completes the building of the major parts for the instruments casing.
David Waite
Next the Brass Casing had its clearance holes drilled for the two Thumb screws
The Brass Casing was used as a template to mark the position of the holes to be drilled into the Aluminium, the two dowels
keep everything at right angles for this.
Tapped 1/8 WW
The next job is to make the Bridge Bearing with its imitation Jewel, I machined a square block out of some round stock a little bigger than I need,
it is always nice to know there is that extra metal there just in case, and yes I needed it, I will explain,
After clocking up the Rotary Table I then clamped the Brass stock to it and squared it up to the milling bed and locked the R/Table up tight, I then started to machine the shape of the Jewel and the screw heads so far so good BUT my eyes the way they are I have to concentrate hard on the machining part of the process and when I accomplished what I wanted to do I naturally looked at the DRO and found it wasn't zero on the X axis it had moved to 0.0700 mm from zero which meant some part of the machining was out so turned it up side down as this can be machined off later this way I had a new surface to start again on.
Now what moved I have no idea I realise the machine is slightly worn as I have done some some heavy work with it over the time and it was never designed to do fine work so I work it accordingly however it shouldn't have moved, the main spindle bearings are worn so I keep the idler to spindle belt tight which over comes this and I keep the spindle lock tight but allowing just enough movement when the Z axis is to be used, anyhow I removed the Gibbs on both the X & Y axis lifted the bed and cleaned it oiled it and reassembled it, no problems there the only thing I can think of is I am running the machine at its maximum spindle speed about 2500 RPM which is driven by a 2HP motor this causes a slight vibration that might have settled something into a different position even though it was all locked up. so its take two I do have enough brass if take 3 or 4 is needed but I'm not sure about my patience will extend to take 4.
2.5MM diameter cutter.
1MM diameter cutter and powered by a 2HP / 1.5KW Motor [now that's efficient no global warming here]
For me this was Eye strain plus.
The only reason the Rotary Table is being used is for the two curved sections around the centre bearing, all measurement's are taken
and zeroed from this position and the job is squared parallel with the milling table as I never go by the degree markings on the R/T.
First pass another 0.25mm has to come off to be on size and the DRO is still reading 0.0000 yippee, this is a slow process with such a slow spindle speed for these tiny cutters.
Tapped 1/8 WW
Quite simply a superior level of modelling, David.
Thank you for sharing.
Jon
David Waite
We have had so much going on over the last week or so I haven't been able to do much on my instrument, however I have been in the shed but doing other things one of them was to make a new spout for the oil can so I can oil the machines the old spout had worn out and wasn't pushing the ball bearing in on the oil points around the machines, the new one dose. The other thing that has taken away some modelling time this week was the front fence my arm has improved enough to enable me to start putting some pickets on the fence the weather is too cold for painting now and the nights are getting damp so I figured if I put as many as I can on before winter sets in I can paint the last coats on them next summer while they are in position on the fence so this week we managed to get 60 pickets on, that a start.
With the little time I had, this is what I got done.
I cut away the baulk of the brass with a 4mm cutter shown in this photo.
I then changed to a 2mm cutter to give a smaller radius in the corners and to machine the two thin arm pieces to their final finish size.
Next was to machine square the radiuses and machine the two thin arms to their finish length.
I clamped two pieces of sheet metal to the bed to act as a positioning jig so once the job was centred it could be flipped over
and the opposite cuts would be in the exact opposite position
The outside of the centre circle still needs to be squared where it meets the two arm sections, this I will need to do by eye,
i'm not looking forward to that.
David Waite
I haven't had much hobby time lately so many outside things to do before winter comes along, the biggest project was putting all the pickets
on the front fence which I have managed to achieve all done yippee!! I will put the final coats of paint on them next summer if all goes well.
Yesterday I had 5 hours free so I machined 0.42mm off both sides of the brass piece to give a total final finish thickness of 5.1mm, I then machined the four 1mm radius concave corners this was done with the 2mm cutter, not a lot of progress but at least some.
It would be nice to have the mill table 12" higher which would take some discomfort away from my back but that isn't going to happen so I use a lower chair then I've got to get up from that, to put my head in all sorts of weird positions to try and see what I'm doing, I constantly move the lights around for better vision but in many cases I just cannot see, so I'm at the mercy of the DRO and hope to goodness its set correctly including allowing for the play in the machine, most of the time I watch for the chips and the sound of the cutter but that isn't easy when most of my good hearing has gone, the joys of age grrrrr.
michael mott
David your tenacity for getting the best results from the materials and methods available are nothing short of amazing! So many steps to keep track of I take my hat off to your ingenuity.
Such a collection of legacy pieces that will outshine your layout in my humble opinion.
Michael
David Waite
The back of the Bridge was machined to its final size being 6mm in thickness as you can see those clamps got in the way again, the piece was shimmed up off the table so not to damage the finished face side.
Next was to machine the end sections to their correct thickness they are much longer than required my idea for this is to give more support and clamping area when it is fitted in a jig for the last major machining process.
The cutter marks were removed on both ends with 1200 WD the piece of pine was used to keep everything square.
Next a Radius was cut on both ends, the cutter is a 4.5mm Radius cutter.
The Radius needed to continue further up to the top and finish at the start of the thin bridge section but the cutter can only do what it can do so I will file or sand it to shape when I tidy up the marks left behind from the cutter.
This is where I'm at.
By the time the final metal is cut away it will become very delicate item of course the prototype was bigger so naturally stronger, I would love to have been a fly on the wall and watched how these original pieces were made, their shapes seem to vary a lot between each one so there must have been a lot of hand work and hand machining involved making these more so than jig built on machines.
The mounting screw holes being drilled with a clearance drill to suit 10 BA screws.
The final machining needs a jig to hold the job secure its seen here being made from a aluminium solar panel bracket I found left behind on a roof,
its surprising at the amount of stuff I've collected over the years some I have found a use for, others well they just live under the bench.
The slots being cut are on size and will hold the Bridge piece in with a firm push fit, the length is also on size to prevent it moving length ways.
Small G clamps will be used to hold it in the slots on the jig this is the reason the end sections are longer than required.
David Waite
A vice in a vice, cleaning up and shaping the missing part of the radius with a home made 1200 WD sanding stick.
Mounted in the jig for the removal of all the unwanted material the markings are just to show me where the finish size is, the DRO is what I'm going by.
One more pass to take the bridge section to 2mm in depth using a 5mm cutter which will also give the finish 2.5 mm radius in the end corners.
The machining is all done, this photo shows the flat end mounting sections being cut off to their correct length.
On nice mornings when the sun is shining I like to have my 10am morning coffee under the shed verandah which faces east, lately I
have been watching the Honey Eaters hover around a flowering shrub getting the Nectar which they do each year, anyhow yesterday I decided
to get the bridge piece and my magnifying head piece out and sit in the morning sun to see what I needed to file off to smarten it all up .
What I seen was amazing the natural light revealed so much the next two photos was a experiment to see what the difference was between the shed lighting and natural sunlight.
This photo was taken sitting under the verandah in the morning sun I can see so much in this view, not only the colours are rich but all the swarf, scratches and burs are visible.
This photo which I tried to take a similar view is in the shed with all the lights on including under the LUXO led lamp, what a difference natural light has on what I can see compaired to this photo
This got me thinking, reading the recent post on work benches I thought to myself why not make a portable workbench that I can wheel outside under the verandah when the weather is nice to do the things that I would normally do inside under Fluro lighting.
So today having my morning coffee I sat in the chair and worked out what height I needed for the work bench including the depth and width so when the coffee started working I got into it.
By midday I had found a piece of timber that would do the job for the top nicely and scrounged up odd length pieces of 40 x 40 x 3.2 mm gal RHS and cut them into the lengths I needed and also drilled the holes to hold the top on, then got everything set up and went for lunch.
This frame will have some weight in it with its thick walled RHS the idea is to keep it solid and let gravity do its job in preventing movement.
Being a professional welder as part of my trades for a good portion of my life I now call myself by various names which I won't mention here when I run off a weld line, now days my eyes just cannot see where I'm going half the time and the weld can end up in very strange places which I get extremely disgusted at of course nothing that cannot be fixed, the job that is.
Today I did manage to keep on target.
By 3.30 I hade done enough for the day, tomorrow I might put a tube on the rear somewhere to support the LUXO lamp for when I use it inside and there will also be two wheels fitted at one end so it can be tilted and moved around like a trolly [ hand truck ].
David Waite
you need a mig, not a russian one either
Yes that’s what I used yesterday (not the Russian one) and it still doesn’t help in fact it’s worse than arc as the wire is thinner than a stick so is harder see, In fact the game changer for me has been the electronic helmets that has kept me going as I cannot use fixed lens type anymore I have used them for many years for convenience but now I rely on them.
David.
David Waite
I made up 4 brackets to support the two wheels out of some off cuts these were welded to the frame at a height which allows the wheels to clear the floor when the frame is sitting on the ground.
A handle was made up and a piece of RHS that the handle shaft would slide inside was welded to the frame this will allow the handle to slide down below the bench top at the back when not in use. A piece of solid rod was cut and bored to suit the support pivoting shaft of my LUXO lamp this was welded to the top RH corner at the back.
I brush painted a Zinc coating over the entire assembly seen here, followed by a coat of Metho based etch primer.
The top coat is a Grey Hammertone Enamel, I have had this partly used tin for many years sitting on the shelf which I thought would look nice. When I opened it the paint was starting to turn to jelly so with nothing to loose I mixed some enamel thinners with it, well to my surprise it thinned out ok with no lumps, as you can see it sprayed on nicely, I fitted 4 knock in plastic tube ends as the feet for the table.
And NO it's not a Walking frame I'm not there yet.
The Timber Top,
This piece of solid pine was the bench top of a old cupboard it is 40mm thick and 520mm wide and 2300mm long
there is no bow in it and no splits or cracks and was made into a bench top over 120 years ago which is amazing.
The cupboard that it was on was eaten out by Termites but for some reason the top wasn't touched which is odd as Pine
is like sweets to them , anyhow I kept the top knowing that someday I could use it for something and now someday is here.
Can you imagine the Diameter of the saw blade that cut up this tree.
The top side is well marked and with nails and tack holes ect there is also some shrinkage which has left the centre 4mm higher
than the thickness of the sides so the next job is to level the top surface.
It took some doing but I got there, the holes are now puttied up, there are some Blue ink stains from a fountain pen these
have soaked well into the wood so are there to stay, I wonder who spilt it?
Next job will be to cut it up to size.
David Waite
A baking soda poultice should lift the ink in no time!
Hi Dave thank you for the tip, I was lucky enough to cut off the bench top that I needed leaving the
ink stain section behind on the remaining piece of wood, I will try what you have suggested tomorrow.
David.
