Hello,
Jerry Colebrooke advised me the autogear coupling bar doesn`t belong at the driver`s end ( at least he`d never seen it there, he said) , so I changed the quite simple casting for the front by adding 3 more parts to make it a bit more prototypical. I drilled a 1mm hole in the "eye" of the coupling and fitted a small 1mm brass wire through it. Then I took a 2mm long, 0,8 mm thick wire , embedded it in a 0,8mm brass stripe and soldered the construction to the end("eye") of the casting. Finally, after having soldered 0,5mm wire to a 1 mm brass stripe, I drilled a 0,5mm hole into the middle of the whole construction and fitted the brass stripe with an eyelet in the 0,8mm wire/stripe construction.
Sorry for my very imperfect English description! Maybe the photo makes it a bit understandable.
Bernd
PS
Just corrected the "eylet" , I drilled a new hole closer to the 0,8mm wire
