Brian McKenzie
Can you advise what the "very expensive stainless steel blackening fluid" is please ?
Thanks, Brian
Thanks, Brian
I find this rusting a little strange as I have always used steel rail through Brockenborough, Braunstone Gate, The Field, Y Cae, Aberbeeg and The Back End. The first five lived in a double loose box with a tin roof that rained after a frost, although Aberbeeg did move into a custom built wooden building. I did have rust after using Carrs Green flux to solder some wiring on. The rust was removed mechanically and then treated with Jenolite. What could be causing the different experiences?
Mark,
it was at Bristol. The scenic bit is 3m long.
Thanks, Brian
Well, if you are successful, it would be good to know, even though it’s a bit late for my layout. Fingers crossed.
