Scanlon
Work continues on both the auto coach and my S15. The auto coach has reached the stage of being a basic body. The second coupe and luggage compartment have been installed and everything tacked in place. This photo shows the driving end
As built the rear passenger and luggage accommodation had the same body profile. On rebuilding by the GWR the doors to the luggage compartment were inset and I needed to modify the kit to suite. Fortunately there are alternative non driving end walls and to maintain the body profile of the tiny luggage compartment the spare etch was used.
Now to strengthen the body build and solder everything solid, currently it's a bit wobbly followed by a good clean up! This photo shows a trial fit of the roof.
The S15 has seen a lot of work in the past few days. Despite having built the frames on the jig I needed to spend a little time on the coupling rods. Initially a crank pin was found to be out of true but the frames would not roll with any degree of ease. Opening out some of the rods quickly solved the problem.
Work then started on the cylinders, bogie, motion brackets and brake gear. Unfortunately work on the cylinders has come to an abrupt halt. The cylinder castings needed tidying up and drilling to take piston rods and valve rods. While one set drilled perfectly the other was made of far sterner stuff and a drill broke off within the casting and could not be removed. I should have checked all the castings earlier but found one set was completely deformed and was covered in a black deposit, the front cylinder cover on this sprue was 2mm smaller than the other. What to do?
I sent an email to Dave (Genghis) and Trisha explaining I obtained the kit from Geoff Stratford just before they bought the business from him. I asked their help enquiring if I might be able to buy a complete set of castings to enable the model to be built. Within 12 hours Trisha replied saying they would source the parts and provide them free of charge. Now that it what I call service, thanks.
The bogie has built up perfectly, very simple construction with a robust centre pin and side to side control. Similarly the motion bracket assembled easily and then I turned my attention to the brake gear.
The instructions said to refer to the enclosed disc for guidance on how to install the pull rods etc. but it was missing. Fortunately I still had the one from the original build. Generally the assembly is straightforward except the brake piston and crank are fitted between the leading pull rod. The written instructions make no reference to this. The brake cylinder supplied in the kit did not fit on the plate designed for it and in fact rubbed on the leading axle. My trusty spares box provided a slightly smaller cylinder which has proved to be a perfect fit. The photo shows the trial fit of the brakes.
