Well as promised here are my first efforts.
Before I started I had to clear up my "work bench", pot of Yorkshire Tea to make the task easier.
Then we got to this:
And some goodies on their to start work on.
I have decided to give the fish van a go first, seemed the simplest & being a van my first attempts at soldering brass can be concealed inside.
Quick read through the instructions & start removing parts from the etch, parts cleaned up really easily, this will get easier as I cleaned up etch tabs which will be concealed after the build. (Every day is a school day).
Sides & ends folded really well, after I realised that I put a slight bend in the recess for the slighting door, quckly flattened that back out. Second side was folded with only the part to be folded proud of the Hold & Fold, this kept everything flat, apart from the bend I needed.
Ends folded up as intended after I carefully looked at the drawing, and realised the ends have a double bend
Offer ends & sides to each other and to my amazement, they slotted together & were square!
So without further a do, I heated up the soldering iron & tacked the ends on. Checked everything was square I went inside and ran solder down the inside of each corner. Initially I had the iron set at 300 (I am using 145º solder) but for the seams I whacked the heat up to 400 and got in and out with nice flowing solder.
After that my feeling of actually achieving something kicked in and as I was on cooking duty, I cleanup up the body in hot water, with a little Bar Keepers friend & an old toothbrush.
Tomorrow we move onto sole bars etc.
What would I do different I would clean up the flat brass with very fine emery paper around where the solder joins are going to be made. Trying to get inside once I had tacked top & bottom just wasted time.
Not be afraid of using the power of the soldering iron, pussyfooting around with little heat doesn't work.
I am going to go with sprung W irons, that should add a bit of interest to a first wagon build!
More as I crack on
PS Jelly Beans aid concentraition.
