OzzyO
Hello all I thought that I had this thread going on here as well as over on **web but I don't if any one wants to see what I'm up to on the build this link should take you to it.
http://www.rmweb.co.uk/community/index.php?/topic/70310-anne-and-me-from-the-das-kit-in-7mm/
When I started to have a look at the fit of the steam pipe casings in the kit I was not that impressed with them, as something just looked wrong.
The build up to now, I've still got a lot of work to do on her.
This is a copy of my last post on **web.
well I did have a day out at the N.R.M. looking at drawings for Anne and some other things. Out of all the drawings that I looked at I decided to buy two and also get them on C/Drom as well a very quick way to spend £100.00 but the drawings are about 3'6" X about 7' clear as a bell to read but a bu99er to work on at that size. I think that if I get any more drawings from them I'll just get them on C/Droms in future. The N.R.M. has a good number of drawings for Anne but the one drawing that is not in the collection as far as I can see is the following one. D52-21040 Steam pipe casing at smokebox. If any one knows of this drawing I would be most grateful to see it or get a copy of it (any cost would be reimbursed).
As I mentioned in one of my last posts about the position of Anne's front footsteps being next to the hanging plate, when you look at this drawing you can see that the footsteps are only 1/2" outside of the buffer beam, not like in that photo. In the same drawing it looks like the running plate was going to be open like on the latter Duchesses as the curved part is not drawn in and the small step is mounted onto the side of the frames.
Now onto the reason that I bought these two drawings, the front steam pipe casings. Using this one I should be able to work out the corner radii, all of the bolt spacings (that will be simple), and approx length of the casing.
This one is the same as the one above but with less clutter.
On to the side view, at first I was trying to think what the two extensions were above the main casing, then it clicked they're the flange for the mounting bolts. The dip in the top edge I'm not so sure about (any ideas let my know), you can also see how high up the top part of the casing goes up the smokebox (the line just above the top is the smokebox centre line). So apart from showing the steam pipes we now know what is behind the casings.
This one is very good in that it shows the full width of the casings from the rear, it looks like the main part of the casing is just about above the outside cylinder line and that the main part was vertical. Could it have been made this way just in case they needed to fit smoke deflectors at a later date? It will also come in very handy when I come to start fitting the oil-boxes at a latter date. The only down side to these last two drawings is that there are no dimensions shown, but I do know that the dimension between the frames is 4'11/2" and that the smokebox radius was 3'1" I'll have to check whether inside or outside. The side view will be a bit harder to work out the dimensions on.
All drawings are copyright to the N.R.M. and only used for information purposes.
All in all a lot of very useful information. Was it worth the £100.00? time will tell.
OzzyO.
OzzyO.
