OzzyO
Hello all,
are you not feed up with these casing yet because I am and I'm making the things, this should be one of the last posts on them (I hope). The starting point was to get the main steam pipe cover to look something like, the top edge is still a bit thick in this photo, but it will get reduced a bit more.
Starting on the curves for the front and rear edges of the main steam pipe cover, there is still a bit of work to do to it at this time.
Just about done. My god the photo does show up all of the scratches that a file can leave. I'd better get out the wet'n'dry latter.
Trying the smokebox in place in the casing, not to bad a fit! A lot of the gap is due to a row of rivets that should be above the steam pipe casing being below it in this photo so some or all of them will have to come off and be replaced with transfers (I will only use the transfers if the spacing is about correct and the size about right to the rivets that are on the smokebox now) or I will leave them off.
The same when the casing was placed on the running plate, but you can now see the rivets, if I'm correct these rivets will need to be moved up by one row of rivets at both the front ring and the rear ring to make them look correct.
From the front, the smokebox is to far forward in this photo, but I think that it shows a better looking front end?
Starting to look at the work on the flange plates for the casings, as some of my drawing did not have all of the sizes on them I have had to estimate some of them. Looking at the bolt chart for the casing these were held down using 1/4" Whit. bolts, so that would be a flange of approx 1 1/2" . For a nut size of approx 1/2".
The casing flange plates cut out and at the bottom the plot for the bolts (rivets) and at the top the bolt heads (rivets) this will be the side that you can see.
I've now got them in place but I'm not to sure about how I'm holding them in place as I'm only using Loctite to do the job. I'd have liked to use solder but I have a lot of soldered joints that could have failed if I had applied a lot of heat, and it would have taken a good bit of heat to get this lump in place.
OzzyO.
OzzyO.
