B1 - 61161
65179
Mmmm. Four, I think, Simon.
The preserved 1264, that I based my speedo mounting design on, uses 4 slot headed countersunk screws that are flush with the outside face of the valence. I thought wouldn't really show on a 4 mm scale model, so didn't bother. However, checking photos of loco in service, in the Yeadon book, seem to show snap head fixings, which definitely do show. Have you any decent , side-on, photos or drawing showing the attachment arrangements?
Just goes to show the dangers of using preserved locos for information.
Dave.
I was going off this image I posted before:
Post in thread 'B1 - 61161' B1 - 61161
but now you mention it the last rivet is probably in shadow.
Dave Holt
Thanks for the additional photos, Simon.
Fully appreciated as a joke, but it has made me think that the original snap head fixings are quite noticeable. So, I've designed a simple drilling jig that locates on the speedometer mount and up against the protruding footplate edge. Whether or not I use it is for a later decision as the holes would be rather close to the edge of the footplate plastic moulding, with the risk of breaking out. We'll see.
I'm trying to get down to progressing the tender and have added some lead ballast to the chassis, fixed using slow setting Araldite - don't want any risk of it coming loose in future.
Dave.
65179
Dave.
Possibly a job for rivet decals (Archer or similar)?
Dave Holt
I bought a sheet of Archers rivets years ago, for possible use on the C13 tank patches (but ended up with half etched N/S overlays), but have never used them. I have no idea where they are now.
Anyway, attention has turned back to the tender.
I had intended to paint the inner parts if the chassis before fitting the wheels but have got a bit carried away and the wheels and bottom cross members (which in effect make the wheel sets captive) have been fitted after attaching the spring wires to the bearing carriers. You can just make out that parts of the chassis have been painted with etch primer, as seen below.
Here's the current state of the chassis, with the scoop operating rod temporarily fitted using 0.35 mm drill bits through the forked ends.
In the instructions, it mentions that the scoop rod passes through some sort of guide. where it passes under the front cross stretcher. Has anyone any information about the nature and position of this guide?
Dave.
Dave Holt
After fitting the loco speedometer mounting bracket, I noticed that the fireman's seat was missing from the cab. It must have become detached during all the handling and flicked somewhere in the room. A search of work bench and floor failed to locate the missing item, so some replacements were requested from Justin at Rumney Models.
One of these has now been fitted but this time I've used epoxy resin instead of cyno. Hopefully, it will remain better attached than it's predecessor.
Apologies for the slightly fuzzy photo.
Dave.
Dave Holt
The scoop operating rod has now been fixed, complete with a representation of the guide - which turned out to be a bolted on, "U" shaped, hoop (thanks to Dave Bradwell who sent me extracts from various GA drawings). My version is made from a bit of suitable width spare etch that was annealed to make it easier to form round a drill shank.
Also fixed is the rear portion of the brake pull rods.
Dave.
