I've discovered another photo of pipes for the Lake Vyrnwy – Liverpool pipeline being unloaded at Llanrhaidr Mochnant in 1931.
This is a good side view of the road trailer used to carry the pipes, and the "motive power" is a GWR Fordson tractor. Seems to have been taken the same day as the photo in Mike Lloyd's Tanat Valley book, but a different pipe with an "advert" on the side.
The Talbot process being advertised, was (is?) a method of coating the inside of steel pipes with bitumen & a filler. The pipe was rotated at some speed and the bitumen applied by centrifugal force.
The crane is a former Midland Railway one, bought by the Cambrian Railways, which was by the time of this photo, GWR No.466. Haven't so far found any good photos of this crane.
In this photo, at the far right, two pipes can be seen side by side on a wagon, though I don't know what sort of wagon it is. The wagon end has a pattern of strengthening ribs, and the body is probably at bit taller than double bolsters.
The pipe size was 25 feet by 3 feet 6 in, so it was possible to scale the photo to 4mm scale, and make a pipe trailer. The other photo is more 3/4 rear, so is a help, though some details have had to be guessed.
There is a hand brake which seems to work on at least one front and rear wheel, possibly by tightening a metal band round a drum behind the wheel.
Here's the model – 3D printed in quite a few pieces. The main chassis structure is two halves, split horizontally, to make U channel when joined together. The front wheels seem to have had a mudguard, but not the rear.
Pipes weren't, AFAIK, unloaded at Blodwell Junction, but the trailer makes an unusual wagon load, which could have passed through. Excavators for the pipeline trench arrived by train in 1931, which will also make for an interesting wagon load: a work in progress at the moment.
