I think I might have got to the bottom of the story re spring hangers. When originally designed both top and bottom of the spring hanger had a collet arrangement with various thickness wedges inserted to alter the spring rate and hence weight distribution. This was a mighty faff to alter or change a spring so someone came up with the idea of converting the lower end to be retained by a nut and locknut, much as a Black 5. What is important to know is that this happened in the preservation era and didn't pertain to locos when withdrawn by BR.
Having recently started a MOK kit of the 4MT I find this thread very helpful. Grahams post 27 describes the kit as supplied and I am building 80064 as it was at Watford in 1959. There are several photos of the preserved loco but none I can find of the relevant spring blocks, modification would be relatively easy if needed.
The Bluebell is a long way from here, anyone have an answer.
Ok last lot
Front left buffer.
Bogie frames.
Bogie again. It was cold and raining at this point and I wasn't inclined to hang about, I'll take some better ones another time.
Drivers side cab interior.
LH tank side.
RH tank top.
LH tank top.
Crosshead again, why?
Set up on the surface table to establish centres.
The slot where the cotter goes to hold the piston rod in.
View attachment 82578 View attachment 82578
The other crosshead showing wher the drop link is attached.
Slidebars.
Slidebars 2, They are big and heavy.
Valve and cylinder casting.
I think that's enough from me, I hope that the pictures give some useful detail of the bare bones of the loco. If I can get over there on a decent day I'll take more detailed pics of the bits currently lying outside. If anyone wants something better pictured just ask.
Martin
PeterHi Martin,
Interesting.
Do you mind if I post some of you photos on my thread as and when required? I will mention they are your copywrite.
Cheers,
Out of curiosity, the new tyre looks larger diameter. Presumably the other tyres are half worn or more. Do you have to turn the new tyre down to match the diameter of the worn tyres? I imagine there would be problems with excess wear in the coupling rod bearings and less steady riding with an odd sized wheel on the loco. Is this the case I reality?A few more pics taken today.
The driving wheels having been turned, the new tyre is apparent.
