Progress continues at a glacial pace.
Arrangements have been made to allow the boiler unit to be attached and removed from the footplate assembly. The kit intends two 10 BA screws though the slots in the footplate into holes tapped directly into the resin under the smokebox saddle. The firebox end remains free until finally glued to the cab front. I really didn't like this arrangement, partly because my representation of the inside cylinder and exhaust passageways are in the way of the suggested screws, and mainly because I wanted a more secure attachment to the cab. I find that, inevitably, the boiler gets used as a handle for picking up the loco (I know it shouldn't, but that's my experience) and the idea of it all just hanging on a glued joint didn't fill me with confidence.
So, alternative arrangements have had to be made.
At the front, a single 14 BA countersunk screw, somewhat further forward than the kit design and clear of the internal gubbins, passing through the resin into a nut soldered to a backing plate which, in turn, is epoxy glued inside the smokebox, as shown here:
At the rear, brass wire pegs have been fixed into holes drilled into the rear face of the firebox. These engage with the opening in the front of the cab which both centralised the firebox and held it tight down onto the splasher tops and footplate.
In the kit, the cover plates along the bottom of the firebox, between the rear splashers are supplied as white metal castings. I thought these might be tricky to solder to the footplate and to have the pipes running along the top fixed without melting part of them so i replaced them with items made from brass strip.
A start has been made to represent the various pipe runs from the cab and along the tops of the rear and centre splashers. Some of these were steam to the sanders and are shown on the Pipe & Rod drawing. An additional, slightly smaller pipe, on each side, is clearly visible in photos but does not appear on the P&R, so I suspect they are either a later modification or are lubrication pipes of some sort.
Here are the pipes on the LHS made from 0.2 mm copper (5 amp fuse wire) for the sander steam and 0.182 mm brass for the mystery additional pipe. The small securing clips are made from flatted 0.2 mm copper.
On with the RHS next. Three pipes on that side.
Dave.
