You already haveCynric, when do i need to place my order for those coach partitions
Excellent.I certainly could![]()
Thank you, learn something new everyday. Shame not have some form of lighting in the shed itself though......lighting would depend on the period but from accounts I have read engine cleaners worked at night with paraffin lamps.
At this scale, one should be considering a working light switchA dangling bulb in the mess room is tempting though...
Hope thats a lot of Rowmark£400 of Rowmark ordered today, not all for this I hasten to add![]()
Ah OK. That sounds like a hard way of earning a living thoughIm not saying there wouldnt be any, just the account I read described getting up at 2am, cycling to the shed and working to the light of a single paraffin lamp.
I have started playing with the roof joists for the mess/toilet, in the absence of any detail on the plan I have come up with something like this.
Im hoping Mike or or somebody could point me in the right direction..... Im assuming that they wouldnt bother to build the toilet partition up .
You need to think quite carefully about it, I cut a lot of parts for a local maker of dolls houses which makes it viable, and you do need to be up to speed with CAD as you spend far more time drawing than cutting. You will also need to be prepared to get your hands dirty aligning and tweaking the Chinese models, after 6 months I am still learning, it is not like plugging a printer into the computer (unfortunately)The planks/doors look very good, I have been speaking to my son in law about getting a laser cutter. The reasoning is, I could cut the sides and ends to size and mark the timber for planked vans and open wagons in one operation instead of cutting with a razer saw. Also make the buildings as you are.
Alan
Guv,You need to think quite carefully about it, I cut a lot of parts for a local maker of dolls houses which makes it viable, and you do need to be up to speed with CAD as you spend far more time drawing than cutting. You will also need to be prepared to get your hands dirty aligning and tweaking the Chinese models, after 6 months I am still learning, it is not like plugging a printer into the computer (unfortunately)
