Fairy nuff - you've obviously done your homework - but that said it still looks odd to me.Simon, Adrian have some faith in me
Banana shaped scan
Banana shaped scan
Alge will be coming later along with some stinky waterComing on a treatMaybe a clump or two of moss in the guttering ,and is it east facing sides that attract algae ?
the window side is SW facing so most of the moss and damp will be on the rear, along with the down pipes.Its one of those where you need a picture handyFairy nuff - you've obviously done your homework - but that said it still looks odd to me.
The local army base at Welford park have helped to remove the ply boarding, I believe it is now on the way to Bath...
no doubt they were 'yanked' off
But I could board it up like this (without the blutack!) which would look the part beside a MFYP Warship
I have been experimenting with broken glass panes bur its WIP at the momentI like the boarded up windows, if this box was out of use you could justify it being partially boarded up by having the rest of the boards leant against the box as if someone was actually in the process of doing it.
Have you though about some broken windows ?...... I was lucky enough to visit a few closed stations in the early seventys & most glass was smashed by then.... BTW rusty corrugated steel was popular for boarding up windows & doors then.
Phill![]()
I think it is my preferred option now. I have a nameplate which I can paint out in blackNow I like that All or nothing that look ace
