Windows time!
My initial plan for 5 laminations in the wall void (see earlier post on the door) wasnt going to work as wall isnt thick enough, so another solution needed 3 laminations including glazing in the wall void and two overlays to sit inside the outer and inner wall
A door ow window is made from 5 layers frame, mullions, glazing, mullions, frame - 3.75 mm and the wall core is only 2mm in this case as the wall is only 1 brick (9 inches) deep. this shot shows that I can get 2 mullions and glazing in so the frame has to be done as an overlay which is a push fit into the wall. this wouldnt be a problem with a thicker wall. Im hoping mylar (which is a thinner material) will provide a suitable solution for 7mm allowing the whole lot to slot inI am confused.... I thought that the entire frame slides into place through a slot in the wall and yet the frame in the picture seems to have a multi-level surface. What has changed in the approach to getting a 3D window inset into the reveal?
The whole building is spot on. This thread is getting better by the day. When will you be marketing them, and under what name?
I think "The Guv's Jedi Emporium" could be one, no doubt someone will come up with a better one.
Alan
Calling Colin can you confirm that the the end Rafter would be attached using a stopped birdsmouth joint as per p141 Jaggard? if so I will need to extend the wallplates
Thanks ColinHeard you shout Guv' in all my time working as a chippy I have never seen it done( I have worked on 100 year old buildings and not seen it) nor have I used that method, may have been in my Grandfathers time.
Just asked Master Carpenter (Dad), he says run the plate through, if it was built in war time then it would less work thus saving time
The brickies may have built as far as plate level, the rafters fitted by the chippy and then the apex of the gable ends built. In some cases I have seen the ridge board, but not always, carried on into the inner skin of brick work.
ATB. Col
