Graham, I think that taper pin goes right through the crank and I think there will be a groove on the square shaft to accept this and stop the crank from coming off the shaft, much as the pinch bolt does the same, IE there being two methods of making sure the crank does not fall off the crank. Bolts fail, mainly through constant stretching and tightening, the pin does not suffer the same stretching, so I suspect that the pin is the failsafe fitting in case the bolt shears off.
I would expect the pin to have some sort of retention on its narrow taper end, a split pin or something but that photo does not seem to show anything of the sort, I'd hate to rely on the taper friction alone to hold that pin in place.
A photo of the crank pin minus the return crank will explain all, I'll see if I have a photo of that part somewhere later this evening, and yes Richard does need to start his A4...to give me some inspiration to get 'one' of my ever expanding list of projects going LOL.
Kindest
Kindest
