Perhaps this thread should now be retitled: "Pushing the boundaries", or more appropriately; "A catalogue of errors!" ?
It had seemed to be going swimmingly well...?
Just before Christmas I had a quick run around looking for materials to keep me busy. One of the things required was a chisel tipped permanent marker pen.
Now it would seem that only one supplier has cornered the market in our part of the world? I wilted a bit at the prices demanded for multipacks but eventually found one retailer selling them singly!
This is what I gleefully bought:
A nice BLACK pen! "Colour as per cap" is what it said on the packaging...
Bet no-one can guess what came next...?
As I applied it to the little white nylon wheels it came out brilliantly
purple..!
I was so relieved to notice that the shade rapidly darkened as it dried though... to a delightfully festive, "antique" bronze colour!!
Perfect for making invisible scratch repairs to great grandma's favourite spelter dolphins or on the botty of a naughty, nudie lady sculpture, but a bit odd on the undercarriage of a locomotive tender eh?
If that were not bad enough, at the slightest hint of moisture the stuff returns to the original royal tint - and comes straight off again.
Not very "Permanent" either then?
So be aware of the ornaments to all New Year partygoers, be sure that sins might only be temporarily hidden?!
What else could go wrong now...
I wanted a really nice solid and hefty piece of ply for the floor, so I had a hunt around the house for the offcut left over from a previous job. Then I remembered that it had already found another use. I would have to buy a whole whacking great sheet for a tiddly ten by seventeen inches!
Mind you, I was a bit concerned about glueing and screwing the sides onto "end grain" anyway, so ended up with an available, middling size sheet of 9mm instead. It just meant that the angles would now have to be made up with 15mm square timber all round.
Now I know I am always banging on about some best practice or another, and one is about always doing drawings for everything FIRST!
Did I heck this time...?
Nah! Thought I could wing it?
Firstly, I decided to use the rest of the new sheet of ply for the sides and ends, reasoning that the truck would likely get some rough treatment, so the stronger the better?
Completely forgot about the extra length, width - and
weight that would impose though!
More of that anon...
Oh silly me - imagining that I could even use a calculator too?
A dreadful tendency for the wagon to tip backwards when sat upon was only discovered during a gentle track test once the whole thing had been firmly stuck and fixed in place.
I was aware that I was pushing at the boundaries.
For 5'' gauge, ground level railways, the minimum wheelbase for four wheeled driving trucks appears to be 10''. I feared however that would still be slightly over long for our curves, so took a bit of a chance and reduced it by an inch...!
I then found that in my haste I had not cut one end of the floor quite square either.
There was only one thing to do...?
Knock it all down and chop an inch off both the ends. Made a bit of a mess of the nice and reasonably neat joinery in places!
Later, much later, when looking at photographs I spotted that the "old Lanky" might have had a similar problem with stability? The toolbox end of their tenders are actually cut slightly shorter than the original donor wagon fronts,
so I had not needed to chop both ends off after all...!!!
I will not try to describe my thoughts on that belated discovery!
Back to square and only one day lost so far...!!
Pete.
