Ok moving on, marker lamps, as built the engines have three lower marker lights, each fitted with 3/4" conduit, the outer ones have conduit on their inner sides, the middle one has conduit on each side. A small detail is that the lamps have a hole in each side, so can be either left, right or middle fitted with the hole not used blanked off. Originally all three lamps were set the same height.
The castings come with a little divot on each side, a guide to drilling and the outer ones are a common casting, which means your left with a divot opposite the conduit entry and not a blanking plug, do we want to add this, of course we do
So, how to replicate the planking plug, in a flash of inspiration I simply drilled all of the way through the lamp, poked the conduit all the way through and simply trimmed back the excess to leave a small round blanking plug. Now as y'all old school electricians will know, there's two types of blanking plug, a round one or a hexagonal one, both retained on the inside with a round or hexagonal lock nut, not that bothers us.
So, if you want an hexagonal blanking plug then just file the brass rod accordingly and fit all the way through. Sadly the only decent picture of 110 shows the drivers side and sods law the plug has dropped out to leave a hole. Anyway, time was ticking so I went for round....if anyone finds a picture to the contrary, please keep it to yourself
You can just see the blanking plug on the outside of the lamp, it's not much but when painted will catch the eye and add that little extra, I did so want to add the inspection elbows, but that'd be a anorak too far I think, having said that I might well do if I can find an easy way to add them now everything is in place.
One other feature of the lamps is a socket on one side, this is a bolted plate, I'm not quite sure what this socket is for and suspect it'll be a place to plug a hand lamp into, I've not added these yet, they're not part of the kit so come under additional details which I'll probably add at the end.
From the front all the lamps fitted and lined up.
Now comes the interesting part, once AWS was fitted the middle lamp was required to be moved up, in addition the conduit runs were altered, a simpler route was designed with the conduit running right across the front of the engine, the middle lamp was then fed from below via an inspection T, the outer ones by inspection elbows, again from below, a set each side allowed the conduit to rise up over the battery box cover.
Winston Churchill has this set up. Note socket on the side of the nearest lamp casing.
Another variant simply has conduit in the existing side holes right across the engine as seen here on 106
34001 - 34110 West Country and Battle of Britain Pacifics | 34106 Seaton Junction 180864 HB64O384
However the engine we're interested in retained the standard conduit fit but with the middle lamp simply moved up, the result is the side conduit has a pronounced dip each side.
34001 - 34110 West Country and Battle of Britain Pacifics | 34110-ExmouthJunction-0662-RPC387-1
I like the electrician on 110, he has placed the inspection elbows with the lid on the lower side, smart guy, they rarely sealed well and it stops the conduit filling up with water
it does mean they are a pig to get the cover screws out, being upside down and all.
So the next step is to fabricate the battery box cover and then move the middle lamp up accordingly, the bracket that holds it is quite
pliable so it'll move easily and the conduits are not fixed to the front plate work, simply passing through holes like the real thing, so they'll flex and bend as well.
Taking a break from the front end it was time to try fixing the cover plates on the resin body, use a suitable superglue the instructions advise, hmmm yes well. All of them fell off at some point, some three times, it's not as though the glue is not sticking to either component, it sticks to the resin very well, and I'd forgotten to wash the release agent off though I had mechanically cleaned the area first, now corrected. It also sticks to the brass as well, just not in the same place as where it sticks to the resin! In the end Roket max seemed to do the trick...so far.
I get the resin body, I really do, but the Luddite in me really struggles with adding dissimilar materials.
Overall the fit is pretty good, some areas of the resin needed trimming to allow the etch to sit properly and as much as we try to get a Rolls Royce fit the real things were battered to bits.
I do have some spare cover plates and the safety valve cover plate has a little ding in it that is kinda niggling me so it may come off and be replaced at some point.
Right, back to the front end I suppose
MD
