The next step was to build up the front end. Martin is at pains in the instructions to make sure you're clear that the front of the jig must not be soldered to the footplate. There are a variety of ways to achieve this, as the photos show I used a strip of paper to keep the soldered components clear of the jig.
The front frames have three options, I went for the SR 1930 frames, but there are two other shapes as well. The front footplate between the frames requires riveting and folding. I strongly suggest you do the rivets before the folds; I didn't and ended up with an unnecessary extra job of straightening/flattening the footplate before it would fit properly.
The three parts will fit together 'dry' in the running plate; the frame parts fit with a satisfying click when pushed in from the front. Once it's all together and aligned with the front edge of the running plate I spotted round with a few blobs of solder. Once happy with the positioning I sloshed a load of flux around all the joints and ran round with the iron, pulling the solder into all the joints and folds. A quick go over with a fibreglass brush removed the traces of solder that were left after the iron had done its bit and we're done:
![DSCF0778.jpg DSCF0778.jpg](https://www.westernthunder.co.uk/data/attachments/60/60269-b432198ca81a7915fa24959aaae07b43.jpg)
![DSCF0781.jpg DSCF0781.jpg](https://www.westernthunder.co.uk/data/attachments/60/60268-3b9ab32c03b39ab99dd69f769ccc5400.jpg)
Bufferbeams and toolboxes next.
