Hi,
In cleaning up some of the navigation for "What's new" I've moved the link under the forum tab - if you use this link then I think the list it generates when you click on the thread title it should take you to the first unread post as it did in the previous incarnation. I still need to check why the button for "What's new" doesn't appear to work the same way but this is an alternative for the moment.
I'd appreciate it if you could test this route and let me know if it's working as expected. I've tested it but some times having an admin account I'm not always I see the same response as a regular user would.
Adrian
So it does, obvious really!Log Out seems to be in the drop down under your name
Making a quotation is slightly different. I used the " button and pasted the text into the quote box and then couldn't get out! I tried Ctrl, Esc, Tab and eventually escaped using the down arrow.
However, the upgade is a vast improvement, so thank you Adrian.
Hitting Ctrl after the text is enveloped by the quote box results in the cursor leaving the quote box and the cursor moving to the next typing line after the quote box. Works for meAs an alternative method can you try pasting the text first into the message, then highlight/select the bit you want as a quote and then press the " button. This I think should just put the quote box around the highlighted text.
I posted a link earlier which works fine but in the post it is grey and sort of blends in with everything else.
Were the links blue on the old forum (I have forgotten already!)?
That's bookmarks, which is a new one to me! What about threadmarks?
Now that you mention the facility... I have worked through the four options which are offered and I find default to be the least pleasant in appearance. I have selected flexile-2 as that seems, to me, to be a more friendly face for the forum rows and buttons as current.I hadn't realised that the upgrade had ported the old Flexile style across. I might turn it off so the it resorts to "Default" automatically.
If it doesn't currently then I can make it so. What file identifiers does the format use?Hi Adrian, @adrian , can the forum support the upload of Anyrail format files?
