Here's my
test link. This uses hex colour #0000ff - blue.
This is the default. Bold formatting applied to both.
Without bold formatting:
Here's my
test link.
I think I know which is the more obvious! The hex colouring is now working for me but I can't honestly detect any difference in the default.
If the link colour doesn't stand out from the surrounding text without manual formatting intervention, it fails to do its job.
Hi,
I can see the differences however as I said it's subtle and it's more nuanced than that. First I'm not that keen on making it bold, for me it disturbs the flow of the text and line separation, when looking at a paragraph it is too far the other way and makes it too prominent and you see the link before the text.
Second the nuance - your links are internal links. Try an external link, I would hope that you find that an external link looks more like your test link. When testing I found Chris's post above a useful yardstick as the link is very short and it is in the middle of a sentence not the start or end.
[Sob] Yes, it was great wasn't it?
I've found
this but not tried it yet. If it works, I'm going back!
As I hope you can see in his original message that the external link is more like your test link. I did try pure blue for the link but for some reason, perhaps due to the shortness of the text and colour "bleed" from the surrounding text then the link colour disappeared.
I found that #080ce7 ,which is very close to pure blue, just made the short link pop out a little better. Obviously a subjective opinion as colour always is.
The tricky problem with modifying the colour of the internal links is that all these elements on the page are also internal links
So making the internal link bright blue changes all these and the page lights up like Blackpool illuminations. So I need to find the right incantation nested classes and link identifiers to modify just the link inside a message body.
