Got a good deal in the wood yard t’other day: a piece of 12mm ply offcut, cut to my dimensions, for what will become the lighting hood; total cost: nowt. Reassured that the gods were at last on my side, the thought that a still sizeable piece of wood slid so easily into the boot of my car, came and went. All became clear when I got home for a test fit: I’d picked up the shorter of the two pieces that had been cut by accident
Due to exigencies of service, I wasn’t able to return until the weekend, hoping to reclaim the correct piece in exchange for the wrong’un. Unfortunately, good husbandry on the part of the yard had seen it disposed of, so no doubt feeling sorry for this daft old sod, they willingly cut me another slice. However, on closer examination, it wasn’t as straight and true as the original, with its acquired warp in the middle. Still, one couldn’t complain as again they total cost came to the square root of zero (I trust the mathematicians amongst us will forgive my heresy), and so out to the garage it went with me trusting to the following unorthodox solution:
I’ll find out later if it’s paid dividends (the lash section of angle seen in the picture will be carved into some form of bracket(s) after it’s painted).
Elsewhere, I’ve been experimenting with some ash rescued from the embers of a barbecue a couple of years ago, waiting for this opportunity. Sieved through a tea strainer (like hens’ teeth these days) onto glue and then sanded, here’s the result:
Looks okay but going to try again and see what difference dropping water and pva into it does, although again it will still be sanded for 4 milli scale. It will form the bit between adjacent lines and sides, ballasting up to it.
Otherwise, I’ve been adding card to the side of the rails onto which the ash will land:
At around 1mm thick, it leaves a smidgeon of sleeper proud. I would have preferred a slightly thinner card, but the only other card available to me was too thin. Once again, I didn’t fancy contributing to the Royal Mail shareholders Christmas bash, and there was nothing available in The Range or Hobbydaft of an appropriate size.
The next job will be to run some thin gypsum into the joints/cracks between adjoins pieces of card, and also the redundant holes in the sleepers around the tie bars of the points. The lot can then be sprayed before painting the track and ballasting.
To finish, these are the lights I’ll be using as suggested by Jeremy:
Edit: forgot to post this one in full. Apologies:
