Very good, but I’m still waiting for the shunting ‘orse...
Here's your diff.... An exercise to see how practical it was. The wrong type for a traction engine, sadly - but would be just the job for a steam lorry..... it works very well (having said that, I suppose they either work or don't...). 13mm x 8.75mm diameter, with 1.5,,mm diameter output shafts. Flanged ball races on the shafts, free floating intermediate gears on a cross-shaft doing the work.
It's a bevel gear assembly 0.3 mod gears..... one can buy 0.2 mod, and get it all a little smaller - but I don't know of a source of suitable gears for other types!
This has £20 of gears in it - a 0.2 mod version would have £40 of bits!
I thought about that but I wouldn't be able to get a good enough fixing on the axles with so little available width.
I've ordered some brass gears just to give it a go.
The latest out of the workshop. The cab and front of chassis is from the Bedford TK artic model from Ebay, and all else is scratchbuilt.
I don't need a tipper - and indeed I don't know how I shall use it - but I did want to see what the problems and solutions really were. This uses a K20 gearmotor for drive (8mm diameter), and is plenty powerful enough for the job. For the first time I needed to drive through a Cardan Shaft, which was fabricated from tube and wire, but works well. Battery is under the load-bed in the tipping body.
