Hmm, well that confirms the bogies are somewhat lacking in relief:
37403 Restoration at Bo'ness - RealRail is what they should look like - the main longitudinal frame member is thicker than the area around the horns. I know it's a common weakness of models of all scales and pricepoints, but it shouldn't be difficult to get it right. Thankfully it's a shape which is easy to resolve and the die needs a further machining run to sort the bottom spring/equalisation beam anyway. The cab fronts may well mean starting again if they're incorrect, which I can't see happening.
