Hunslet Works - LarkRail - Bath.
The vist to LarkRail was a great success and some interesting discussions took place on how to present the layout at exhibitions.
The original plan for the weekend was to take the board and display it on a table as we had done at York at Easter. But on the way down from Leeds I had a lot of holds up in the traffic and this meant that I could not pick Peter Kirmond up on the way and he would have to meet me at the hall.
It struck me that this would mean that Peter could bring along a couple of trestles and we could possible display the board at a height nearer to what is planned for the layout when it is complete. Peter agreed it would be a good experiment to see how it would be received by the public.
Peter also brought along the drapes from his York layout and it all made a real difference.
So did it work - yes it did - there were lots of positive comments, and the height we chose was ideal for operating the cranes, and high enough to allow visitors to look down the shop and get the full effect.
It also was a better height to get an appreciation of what you will be able to see through the side door.
The Wheel shop structure also went down well, along with all the parts laid out in the shop.
I also set up a shot that was similar to a real one from the erecting shop.
I was also busy with the laser just before the show, in fact the night before I set off. The end of the old wheel shop has the original slate roof, so it need all the timbers and lats on the inside. The photo of the old shop shows the detail that will be in the end section.
I have managed to recreate this by using the following. 2mm ply for the roof structure, 0.4 play for the lats and 1mm MDF for the timbers. These were all cut as a panel with a frame around the edge and then glued together.
The effect when the panel is dropped in place is identical to the original. There will be a lot of these panels of various sizes to do as the roof sections of the North lights are tiled, as is most of the pitched section going towards the boiler shop.
I have also cut some tops for the etched benches a few weeks ago and Jill has started to paint/stains these. I tried these in place in both the erecting shop and the wheel shop and again I am really pleased with these.
And last of all, Jill has produced some labels to go on the control boxes for the cranes which are going to make it easier for any trainee crane operator.
The good news is that Peter is now trained and signed off as competent as a crane drives for the double lift and wheeling so he is now a vital member of the operating team.
All in all it was a really good weekend and a excellent exhibition.
It was also good to chat with a few members from this group.
Next outing Swindon in September.
Andy
