S'pose that's the power of WT. Having just posted some vaguely intentional waffle about getting round to making the fall plate for the 8F, I've got off my backside and done it.
The kit has a fall plate in two parts; an etched plate profile and an overlay with a chequer plate pattern etched onto it. The idea is (I think) to sandwich a length of wire in a half etched rebate along the back edges and somehow use that as a hinge along with the tiny lugs projecting from the rear of the cab just beneath floor level. Two problems with that; the resulting plate will be way over scale thickness (and you do see the edge), and I can't see how you'd assemble it and make it work. Cartoon light bulb hovering above head, and this is how I made it work.
I elected to use only the chequer plate etch, it's plenty stiff enough on its own.The plate was profiled and curved to an approximation of the prototype and some tiny lengths of brass tube were silver soldered to the under side to sit between the lugs on the back of the cab. The tube was about 1.0mm OD and 0.6mm ID.
You can see the four lugs in this photo. The cab's upside down by the way. Two 0.6mm holes were drilled in the rear plate, red circles mark the spot.
Small rectangles of brass shim were RSU'd into position on the upper surface to represent the prototype hinges. On the prototype the fall plate was actually 2 plates split in the centre. I've left it as one piece for simplicity. The hinges are completed by lengths of 0.4mm phosphor bronze wire.
Some fiddling, and the plate is fitted in position with the wires. 0.4mm wire in 0.6mm holes makes a nice sloppy fit that eliminates any tendency for the hinges to bind.
The bent ends of the wires are sprung into the holes drilled in the cab . Phosphor bronze wire is springy enough to let you get away with that if you choose the length of the bent end carefully. Easy to take a part as well.
This is the plate assembled to the cab, seen from above. It hinges up and down freely under its own weight and will just rest on the tender. Turned out to be easier than I'd feared.
Need to find the finishing off list and see what's left to do.
