Bradwell WD 2-8-0 - loco brake gear completed
It's been a while since I accomplished much at the modelling bench. I go through phases when I look at the workbench and it doesn't grab my interest. There are easier ways to get a dopamine hit than working through loco brake gear. Sometimes I just want to shake the box and have the kit assemble itself. It didn't help that my son gave me the Haynes manual for the Fairchild/Republic A 10 Thundebolt for Christmas (yes you can get the Haynes manual for that, although I don't think it qualifies you as ground crew once you've read it). That got me looking at 1/48 scale A-10 kits. Huge distraction. Haven't ordered a kit, but the seed has been planted, and I do rather enjoy Heather K's aeronautical diversions, so you never know...
The way around the brake hanger to coupling rod clearance problem was 'simply' to make some shorter hanger brackets. The only drawing I have of the WD doesn't show the hanger brackets so I've no idea how far they stick out from the chassis on the prototype. The etched brackets in the kit project about 2.8mm from the chassis. Careful measuring of the coupling rod position suggested that I could make it work with brackets projecting no more that 2.2mm. How I went about that is shown below.
1- As usual a bracket was modelled on CAD to work out the detail. I decided to make the yellow part just butt joint to the green base so its horizontal leg could be made over length and adjusted after bending. No chance of bending to exactly the right length each time. Since it was to be silver soldered that butt joint should be strong enough to survive the subsequent wrestling with the brake gear.
2 - Ten sets of bracket parts were marked out on some scraps of 0.3mm N/S. Ten because you can chuck away the worst two! Yes, I used callipers to scribe the lines, heresy, heresy.
3 - And to make sure I didn't get the marking, rivet and hole positions wrong I made a spreadsheet and printed the dimensions out in a table. Check before marking and tick them off as you go.
4 - Here's the venerable GW rivet press actually doing what it was designed to do. The material is lined up in the clamp, the first rivet position found, then the graduated cross slide twirly knob is set to zero and off you go by the numbers. The leadscrew is a length of M6 x 1.0 all thread and you'd think that would be reasonably accurate, but getting across to the last few rivet positions I could see it was drifting away from the marked rivet positions slightly. A small adjustment made to get the last few rivets in the right place.
5 - Here they are with rivets formed and holes drilled. The holes were drilled 0.7mm to be a close fit on 0.7mm brass wire.
6 - The parts were cut out with a piercing saw, filed to size and shape, bent and adjusted to length. Fiddly work, particularly when you're trying to hold them in the vice device and not squash the rivets. One day I might make a finer instrument maker's vice for just this kind of work. One day...
7 - All silver soldered up on short lengths of 0.7mm brass wire. The downside of silver soldering is that all the material is wonderfully annealed and you have to be careful not to bend things when you do further work.
8 - Here they are finished and ready to fit to the chassis. A small wire spigot is left on the back of the bracket to locate in the holes etched for the purpose in the chassis side plates. The wire spanning the bracket has a short section cut away to allow the brake hangers to be inserted ( illustrated in a following photo).
9 - Soldered to the chassis using 179 degree solder and a mighty but brief thunderbolt from the RSU. You'd struggle with this if you'd soft soldered the brackets together. Worth noting at this point that the wheel flanges come really close to these hangers, and that's using a Gibson P4 wheel profile. You may be in trouble here with EM or OO wheels and will probably have to resort to some flange reduction.
Assembling all this lot was the devil's own work. Much gumption used up to get everything postioned. The brake shoes were chamfered quite heavily on the back edges to provide adequate side play for the wheels on axles 2 and 3 (yes, if I'd thought ahead |I could have designed them to be printed with a chamfer already included, but then they'd be handed). The brake blocks were left free to pivot on initial assembly so they could align to the wheel tyres when finally positioned. When all was in position the lower end of hangers were soldered to the brake cross beams. The soldered sub-assembly was tweaked to get the brake blocks in position on the wheels and then the blocks were fixed to the hangers with a tiny blob of low viscosity cyano which capillaries into the joint and pivot and gums everything up nicely without leaving much of a trace.
Here's a cruel close up of a hanger and brake block. The block does have nice crisp outside edges, but all shows as a pale blob in the photo.
Here's a close up showing how the brake hangers clip into the hanger brackets. The brake gear is thus removable without fasteners or complication, just olympic standard fine tweezer work. That was Mr Bradwell's design intent, and I have to say it works very well in the end.
That's what I ended up with. Brake blocks that are correct to prototype shape and size, non-conducting, close to wheels, adequate side clearance and removable without surgery. Epic struggle but worth it in the end. I guess this is what you sign up for if you want model locos like this in P4.
P.S.- I think I'll get used to the new format Western Thunder, although I do miss the 'title bar' for your posts if that's what it was called.
