Back to the work bench after a week working at Scotlands biggest real ale festival, a few days away to recover and a bad cold. However I got a whole day today so made some significant progress.
I used the two valances which I had sawn out previously to make a temporary jig to form the curly footplate. The plates were soldered to a bit of thick nickel silver and the footplate blanks cut from 10 thou curved over. I used a torch to anneal the parts where they were to be curved and teased the metal into shape with some offcuts of bar. Once both plates had been formed to my satisfaction they were cleaned up and the jig dismantled so that the parts could be soldered to the footplates.
I have used a rectangle of plate at the front and the drag beam and the back to support the footplates. Before soldering the cutouts for the wheels were marked off and cut out. I used a slitting disc in the mini drill which made short work cutting away the bulk but leaving some metal to be removed once the splashers were soldered on.
The splashers were assembled next. The blank for the front was fretted out of 22 thou plate soldered to a mandrel and turned to size with the front turned down to leave the beading, the blank was cut in two and rolled strip soldered on. The bottom of the splashers were offered up to the curly footplate and then trimmed to fit, quite a time consuming job. The bottom beading was traced off the splasher and soldered on before rubbing flat on some emery paper to blend the beading.
Once all 4 splashers were completed they were soldered permanently. There is very little clearance between the wheel flanges and the inside of the splasher so a piece of thin card was curved over the wheel to ensure they were on the same centres. This would be a bit tricky in fine standard O and would probably need reduced size wheels or oversize splashers.
The top bit of the frames was soldered onto the footplate and the buffer plank just slotted on for the photo.
Next stage will be fitting the motor, pickups and trying it out before finishing the frame detailing. However tomorrow is Scotgog in Linlithgow so I wont get back to the workshop until sometime next week.
