Ian@StEnochs
It’s been a wee while since I posted progress on the Aul Bogie but I was re assembling a previous build after painting. However this weekend I got back to work on the tender, well plural, tenders. I don’t really enjoy making tenders. However they are a necessary evil, especially if you model a railway which did not favour pugs. Making two together cuts the time as it is almost as quick cutting out duplicate parts as it is one. The tender for the Aul Bogie is 1800 gallons while the other, which will go behind an 0-6-0, is only 1500 gallons. Same frames but the tanks are a bit lower.
I had the outside frame plates cut out and drilled for the rivets early on in the project and I had a stock of axleboxes left over from a batch I made when I last built a Stirling tender. The axlebox guides are pieces of brass angle soldered onto the frames on a simple jig before the frames were soldered to the footplate. The axles run in ptfe bearings pressed into the axleboxes and each box has its own coil spring.
The tender bodies are built up from 10thou sides around a base and top, the later with the rivet detail pressed in, and with the flares just folded over. The tool boxes are soldered up and are held by screws to aid painting. The body of the 1800 gallon tender is loose and fixed to the frames by screws because the frames and tank will be different colours. The goods one will be all over green so soldered up as one assembly.
The tender on its wheels looks to be too low but it doesn’t have the springs inserted.
Not sure what to do next, tender brakes or loco valve gear. Both a bit fiddly so I will wait and see what takes my fancy!
Ian.
Ian.
