Old Buffer
Looking very good and the action proved how good the mods are, also you did a great job of not spilling the beer.
Alan
Alan
Thanks again for the kind words everyone.
Alan - Couldn't spill the drink, that would be sacrilege! (It's not beer though - it's homebrewed cider)
Steve - It's going to be 37415, in IC Mainline livery, pretty much the same as in this photo:
http://www.flickr.com/photos/dmc1947/5759297151/sizes/l/in/photostream/
Complete with Thornaby Kingfisher, although it was a Tinsley loco by that point.
I've made the new axles, from 3/16 silver steel which are in two halves. The idea being that, once the traction motor assembly is installed on the axle, it is going to be quite difficult to set the back-to-back measurements accurately. In order to do this, and take account of any error in the manufacture of the axles, the two halves will screw into each other. The wheels will be an interference fit on the end of the axles (reamed 4.74mm), adding to the need to make the axles adjustable.
I don't think I'll have enough functions left on the decoder to have it switchable after doing the lighting - I was going for all lights independent, plus cab lights and I think the Zimo chip only has 8 functions. I guess I could add a second decoder to run it if I decide that's what I want to do.
A thought, Martin, but you could fit a very low current motor directly driving the fan, and have it powered as a bypass to a "shunted" bridge rectifier (used as a constant brightness circuit) from the motor supply: as soon as you exceed 1.4v, the fan will rotate (at a constant speed and direction) and as soon as you reduce the supply, it will slow to a stop.Nothing as yet - I haven't quite made my mind up whether to do it or not. I don't think I'll have enough functions left on the decoder to have it switchable after doing the lighting - I was going for all lights independent, plus cab lights and I think the Zimo chip only has 8 functions. I guess I could add a second decoder to run it if I decide that's what I want to do.
Whilst I have worked my way through your thread here and "over-there" I do not recall seeing any mention of the cooling fan.... what might you have done regarding a rotating fan?
Nothing as yet
Graham,My original question....
And the reply....
Anyone else made a cooling fan operate?
In passing...
What determines the fan speed in the prototype Cl37... engine speed? coolant temperature? a combination of both?
and...
When might the engine be running and the fan stationary? and vice-versa?
thank you, Graham
As far as I'm aware, depending on the particular loco class, it's purely down to coolant temperature. So there will be times when the engine is colder than the fan activation temperature, for instance after starting, where the engine is running and the fan isn't turning. Likewise, there will be times where the cooling system has reduced the coolant temperature below the point the fan is switched on when the engine is under light loading.In passing...
and...
Thanks for the suggestions, but I wanted something that I could control directly on or off, rather than working from track power automatically. I'd also be a bit wary of connecting an auxiliary motor to a DCC motor output like that, as I'd hate to blow up an expensive chip by getting it wrong!A thought, Martin, but you could fit a very low current motor directly driving the fan, and have it powered as a bypass to a "shunted" bridge rectifier (used as a constant brightness circuit) from the motor supply: as soon as you exceed 1.4v, the fan will rotate (at a constant speed and direction) and as soon as you reduce the supply, it will slow to a stop.
An alternative might be the circuit on this link, here.
