Hi progress has been slow as I revised the etches a little and have been doing some other ones, not to mention hatching the ideas for a S7 Southern region late 1990s layout - more on that another time. I've been busily painting away the interior parts of the 37 so thought I'd show you the results. I think my paintbrush best sums up the job here. These parts are ultra small. I've seen the rubber seal around the AWS indicator is a tad smudged so I'll have to attend to that. Note to self - don't take photos of your modelling, it shows up the areas that need to be revisited.
Tom
That is cracking work Tom, but I don't see the sunflower on the AWS indicator
What brand, type of paint & colour did you use for the body of the AWS indicator?
Look on the back of the moulding... one has a "1" and t'other has a "2" - or they ought to have those digits as impressions in the surface.... I don't actually know which cab goes at which end...
Tom
When you "Martin" as the source of the transfers that does not mean a great deal to me. Could I have more details please as Iwould like some of those for mine.
Like the bulkheads Tom - (I've still got some tube and brass chain for you btw) - I must get on and print the transfers for mine.
Have you offered them up to the cabs yet - I had to take off almost 2mm on each side of the bulkheads before they would fit...
Jon
Not yet, but send me some photos of what you want, and I'll see what I can do! These were born out of my 37 project, but I have recently started looking at other notices, etc, that would be suitable for a wide range of locos.Does Pugsley do transfers for other locos? Specifically Westerns, and the speed range ones from an 03?
2 - Drill hole for extra instrument that protrudes at an angle (what is is called??). I've made this from plastic square rod.
