A new commission under way, this will essentially be a photo plank to photograph finished models.
3’ x 1’ x 8” tall.
50mm thick polystyrene base cut through its centre, I placed the two halves back together and marked the track, I then cut either side of the track at an angle to give the impression that the railway Line has been built up. No flat earth here!
Covered first in filler then with decorfill, once dry I’ll PVA then fill again with decorfill.
I’ll make up some sides out of 3mm ply to give it a nice finish and paint in with black board paint.
This will be a simple scenic finish using mainly static grasses with a few bushes.
