The motor has come!
I have test fitted the gearbox and installed the worm. It spins nicely! Now it's time to figure out how to connect the motor to the gearbox shaft, and to connect the tender to the engine; I sort of wish I'd started with a tank engine. Bahs!
I have rigged up a sort of shaft with a piece of wire, where the front end (the gearbox end) is bent in a loop and goes into a captive slotted recepticle at the end of the gearbox worm shaft, and the motor end is just looped through a piece of tube, pinched shut and drilled through; the pics will show it better than I can explain it.
However.... do I have to do it this way? Is there an alternative? This seems troublesome. The end of the worm shaft, where the bent tip of the wire driveshaft fits, is quite large in diameter, and will prevent me using a screw to hold the loco chassis to the body as there's just no room for a nut. I could always solder the screw in, then run the nut up from underneath, I suppose. I still need to figure out how to connect engine and tender.
Ideas? help!
