john lewsey
Hi here is the photo of the chassis. If Im honest im not that good at engines, but I seem to be able to get them to work
Hi Mike is there a photo of itJohn, if you want to be fussy, that frame spacer "boiler stay" went right up to the underside of the boiler with a large hole in its centre. The LMS, as part of their "improvements", cut then off flush with the top of the frames, like yours. It wouldn't be difficult to add a plate directly above it.
Hi they came with the kit. The frames are already cut out and they Just slot in place, I have drilled them and put nits and bolt(screw) to hold them tightNice, robust job, John. Who's make of springing units are they, please?
Hi Mike, I have found it in LNWR locomotives so Thank you for that it would have bugged me. I have been toying with making this into a D instead of a G. The coupling rod etching allow for this. I would have to make new sand boxes and change some of the detail on the front Just underneath the smoke box Door.John, if you want to be fussy, that frame spacer "boiler stay" went right up to the underside of the boiler with a large hole in its centre. The LMS, as part of their "improvements", cut then off flush with the top of the frames, like yours. It wouldn't be difficult to add a plate directly above it.
