NickB
More experiences of using 3DP components. I drew and had printed driving wheel hornguides pretty much to scale with very little compromise, and they looked good.
![3DP hornguide.png 3DP hornguide.png](https://www.westernthunder.co.uk/data/attachments/180/180122-8a03496a36dcc06466e8605c627170ba.jpg)
The problem was the narrow crossbeam at the top. On the prototype it doesn't matter because it doesn't take any significant load, but it's a different matter for the model. The prototype axleboxes have underhung springs that transmit the weight of the engine directly to the frames. I could not use that on the model (now someone is going to tell me how to make working leaf springs of exactly the right strength) but chose the usual modeller's arrangement of coil springs above the axleboxes bearing on that there crossbeam. The crossbeams would be taking most of the weight of the loco, they would flex too much and ultimately fail.
My first attempt was a little piece of angle above the crossbeam to strengthen it.
![3DP hornguide strengthener.png 3DP hornguide strengthener.png](https://www.westernthunder.co.uk/data/attachments/180/180123-e6956a56f0fcb0a91085f36a28de36b4.jpg)
It wasn't terribly successful and I didn't like it because it looked like the bodge it was. The photo also shows another problem that arose in rivetting the hornguide to the frame. I didn't want to rely on epoxy alone considering the shear load there would be and anyway, rivets are prototypical. The softness of the plastic meant that it was difficult to set the rivets well, and if you look carefully you can see some of them bent this way and that.
So I gave up on the printed components and my friend Mike Palmer very kindly made me a set in brass on his CNC mill. In doing so we had to loose some of the detail but the result is much more robust and could be soldered in place. The rivets are now cosmetic.
![CNC hornblock.png CNC hornblock.png](https://www.westernthunder.co.uk/data/attachments/180/180124-caef407fc6dd551c5ef30074595d389b.jpg)
The photo also shows the new motion plate and the rear covers of the cylinders which I had to redesign and replace because it proved impossible to attach the slidebars to the original one without a 1:22.6 scale spanner and 1:22.6 scale fingers to hold it. F360 does a lot of clever things but fails to warn you about that.
The bottom line: 3DP technology (as we amateurs know it) isn't ready for components that take any sort of load.
Thanks to Mike Williams' good offices, I have recently acquired a copy of the Bill Finch Portfolio of these locos. What a wonderful resource - full of detail sketches of all the fittings which clarify the works drawings immensely. Oh, but all those extra fittings to model. When did I say this would be finished?
Nick
Nick
