When I built my pair of JLTRT Derbys, I thought it was a nonsense that you couldnt get the wheelsets out, so I drilled and pinned them:-
Obvs wont work with your model Mick - but in the future...
For some reason - I have a couple of right hand 25 frames if you need them...
Hiya Simon ,did you ever do a video of Abberbig ?Mick,
I did a similar trick on all the locos on Aberbig. A strap and pin bonded to the bogie outside casting; a 10BA screw attaches the strap to the top surface of the bogie inner. Two pins to locate the outside correctly. Photos if you want![]()
I do have a plan for one of the three to rebuild but just need to check some drawings. These three will all be mine
. That'll get the chattering classes going.
