Back to the A2 and time to work up the frames.
The first issue was the laminated springs, cheap as chips to produce, expensive as hell to clean up and make presentable if you on power by the hour, simply not fair on the customer.
Luckily Ragstone do some very nice cast ones in both flavours, brass or white metal.
One of the issues that can be encountered when using the Hobby holidays jig is for the axle shafts to not be perfectly parallel, a trait of how the axles are fixed to the slides and the locations of the adjustment screws within the axle jig blocks.
In addition, it's quite a faff trying to solder from the inside the sprung horn blocks once the frames have all been assemble, so an easier method was tried.
Shorten the jig axles to reduce/eliminate and chance of error over their length and simply work on one side at a time. This is very easy if the engine has equi-distance wheel spacing, not so for dissimilar spacing.
I always leave one axle with a top hat bush in as the fixed reference point, in this case the rear one, the strip of wood keeps the frames clear of the big heat sink that is the jig blocks. It's much easier to solder the sprung axle guides in place on the flat and easier to ensure they are perfectly vertical.
Once the first two are done then cut out the rear one and using the same set up, solder in the last sprung unit and you should end up with something like this.
Repeat for the the side and then join together as one unit, more on that later.
The cast springs are then added, they needed to be made removable as the wheels are cast Mark Woods affairs and unlike Slaters there is only one way to remove them....downwards.
Small countersunk head 14BA screws pass through the frames to hold them in place.
These are just accessible inside the wheel rim between the spokes, the only downside with the accessibility is that they are now also visible and not hidden by the wheel rim. The solution will be to fill in the slots on final assembly and add a dab of paint to disguise them.
Not really sure why the kit openings for the horn guides are so large and I now need to add so lower axle box stops as there is currently way too much downward travel.
