Okay, three prints in the bag, mixed results/feelings really
There's no shadow of doubt that the detail quality is leaps and bounds over the hobby printer, even at 50 microns.
However I'm struggling with surface quality at the moment, some of that is down to the way the machine works, some of it down the choice of resin, there are smoother ones but trade off in detail I suspect, some of it is down to me not having a clue and the rest is down to my being cavalier in the first few test runs.
I get the reason behind the printers lack of tweakability, it's a pro printer, you upload and it just does it, but there are some parts I'd like to mess with in the settings and such like.
Much like the hobby printer, orientation is everything, as are supports, the prints exhibit the same failures as the hobby printer if you do not get it right, nothing new there but I had kind of (vainly) hoped that the upload and print aspect would offset some of that error factor with clever software or whatever.
Don't get me wrong, the errors are vastly smaller than you'd get on the hobby printer but they occur, in simple terms, you still need to know what you're doing.
I picked two objects that I really want to progress as prints, they are hard objects to print and require careful though to orientation and supports, I did neither, mainly to see what the printer would do if a monkey just hit auto support, auto orientation (I will confess I did alter it a little as it was quite clear it wasn't going to work with what the software chose) kind of thing.
Both of these parts have been tweaked to work with the hobby printer, consequently when joined there are gaps, the pro printer is significantly more accurate with interference fits and tolerances.
The SD35 nose section.
Essentially a four sided box, negating the front is two sides
The trick here is to keep the sides parallel which requires extra supports, you can see I didn't and the lower rear section has bowed outward, this became exaggerated when it was cured and the UV light chamber is also heated. A simply solution would be a simple sacrificial transverse rod, say 3 mm in dia between the sides.
That does run the risk of that small section where the rod joins the inside remaining the correct width but the area around it bowing out, you end up with a shallow dish on the outer surface.
The vents came out well and are the correct profile when examined under magnification, the battery box lid (on the conductors side footstep) handle clip came out well too. The hand brake recess is fine but a little distorted along it's top edge, by eye it looks fine but the close up photo shows a slight bow in it.
The EMD Spartan cab front.
Another hard object to print as it will have a tendency to curl or bow. The glass rubber beading came out well and the wall thickness behind is very thin, despite the overall thickness. The test piece is an attempt to have resin sides but in the areas of glazing, be as thin as an etch, kind of....nearly...flush glazing.
The light board inspection hatches and catches came out fine and the headlight details also worked well too.
The door weather strip is too thick, a carry over from the hobby printer that always tended to under print this, therefore it had to be artificially enlarged at source to get the right result when printed.
The combined pair.
Overall not to bad for a 50 micron print, the thin edge around the nose recess for the SP light package is especially nice, a mere 0.40 mm thickness, there are a few horrido's on the surfaces in that cut out section though.
I wasn't too happy with the sand valve cover latches so I've made a slight tweak to them and now running a new print at 25 microns with more thought give the support placement.
The logical step would be to combine the cab front with the nose like I did on the CF7 test shot
Unlike the CF7 the separated nose and cab front can be used on other engines other than the SD35, a kind of parts bin of standard parts.
However it might now be advantageous to combine them and even add the cab sides and roof as one printed module, then simply make up other modules as required.
