Mick,
This is brilliant as fitting DCC sound into highly detailed prototypes is always a challenge. Adding this type of arrangement to other builds would be very helpful towards dealing with this. I really like your solution - another arrow to your bow going forward? Did the chip come loaded with the necessary sound files?
Tony, Simon,
Cheers, I cannot take all the credit, Richard Spoors and Peter (PAD) had the idea first, probably even others I'm unaware of, on Richards A2 I inserted an inner boiler tube to aid guiding and holding the speaker and chip into place. Fitting was via the firebox with the model upside down and all a bit of a faff. Richard and Peter had done it through the front with a bayonet type fitting smokebox door.
Unfortunately the four lugs on the King Arthur door prevent it from being turned to secure it with a bayonet type fitting, so I had to come up with something else. Whilst doing that I decided to try and make all the DCC one sub assembly that fits onto a sled you can just slide in an out.
You have loads more room if you do a Maunsell engine as the door and associated flange have a greater diameter, the Urie one by comparison makes tolerances very tight. The worst part is the shoulder of the DCC chip when mounted on the breakout board, at one end are a row of chips and they push the envelope in the top corners right out to the max opening you can get away with on the Urie door.
The upshot was to lower the tray but then keeping it full width meant that the lower corner cut outs in the face plate would be seen outside the door. To resolve that the tray was narrowed and the sides angled, it means the tray is just a bit narrower than the DCC board but the stand off screws jack the board base up to allow it to pass through the max width opening available.
I still need to add the wires to the relevant tabs but I think we have room to do that and make sure nothing shorts out, it's all very tight but this is the biggest chip and probably speaker you can get in a UK outline steam engine.
What we have above is the MK II rendition, the Mk I had the speaker under the chimney but feed back suggested sound would not be that good, especially jacked up on the pegs to give clearance.
On the Mk I you can see how close the chips are to the cant rail/shoulder cut outs in the front plate, the speaker had to be jacked up to overhang the tabs on the DCC break out board and reduce length.
A couple of beers and some after shot doubles (a good German engineering friend I worked with on crane projects, told me all solutions lie in the bottom of a beer glass, the level of the problems difficulty was measured in the number of beers need to be drunk to find the solution), along with scribbling on a napkin resulted in Mk II with the speaker and chip flipped.
It does mean that the sound is now going down and out of the middle of the loco; there is an opening in the boiler base etches, this is to enable the original kits planned drive to the middle axle. I was going to blank that in but leaving it open will drastically improve the sound quality, so that's a compromise I'm happy to accept.
The chip has no program at all at the moment and I'm tempted to leave it to the DCC guy, but to save any potential cocks ups I might load a US diesel pack in to test motor control and make sure the speakers all work. That way the DCC guy just needs to drop it on the test track and reprogram, no need to take the model apart at all. We'll see how I feel toward the end about it all.
If a model allows and the required chip and speaker fit then this'll be my preferred option for future DCC model installations, it's a lot of extra work, more than is readily apparent I suspect, but the benefits far outweigh the early pain.
