Bimbling along nicely now with the Finney7 Duke & 2500G tender.
As is my want a few tweaks to suit my build methodology, the tank sides are half etched with a flat beading along the top and front edge, for the coal rail version you need to remove the front edge, cut the inset section out and then add new flat beading at the inset.
It took nearly as long to write that as it did to cut a whole new tank side and rear sans flat beading, next I'll add the correct D profile beading and reinstate the strengthening strap along the base.
One thing I have found is that when trying to form the flair, half etch beading can make a crease in the platework, probably just me being ham fisted, I find not having the beading there helps me form a better/smoother flair. The D Shaped beading does also bind the top of the corner fingers better as well.
The only other change was the footplate valances, these are also half etched and very thin, mine were over etched so the rivet detail was a bit light and at one end the depth reduced due to the over etching. Simple to just cut new ones from brass strip, punch the rivets and fit.
I doubt I'll finish it tomorrow but end of play on Weds would suit me schedule and planning.
